Author Topic: gas engine deiseling??  (Read 6789 times)
Offline dirtmod0
« on: April 23, 2009, 06:37:08 pm »
Engine is a Vortec 350 with alum. Edelbrock intake and a Carter 650 electric choke carb. Every once in a while it it will diesel on me, very annoying. I have intial timing at about 18 degress and 32 at 3000 rpms. I run 87 octane maybe should run 89 or more? spark plugs are 44 long reach AC Delco r44lts.
What are your suggestions, I checked to see if carb was leaking after shutting off but didnt see anything.
Offline TexasRed
Re: gas engine deiseling??
« Reply #1 on: April 23, 2009, 07:55:00 pm »
What's the idle speed and is the choke operating correctly?
Offline exilous
« Reply #2 on: April 23, 2009, 08:59:36 pm »
does it diesel for an extended period of time after shut off? or is it just a quick half second burst?
« Reply #3 on: April 23, 2009, 09:49:49 pm »
Check your idle speed first.
Offline dirtmod0
« Reply #4 on: April 24, 2009, 05:33:42 am »
I will check dont have a tach. now that u mention it it seems to idle up sometimes and after putting in park after engine is warm, what would cause this? before I leave for work this morning I will tweak the choke a bit and see what happens.
« Reply #5 on: April 24, 2009, 07:21:29 am »
Make sure it's completely off of the fast idle cam when the choke is open.
Offline gold84gmc
« Reply #6 on: April 24, 2009, 07:26:10 am »
my engine used to do that....so i lowered the idle and now it doesnt do it anymore so i would check that
92 buick century custom 3.3L
Offline dirtmod0
« Reply #7 on: April 25, 2009, 06:08:47 am »
I am thinking its getting stuck on the fast idle cam, I am gonna turn it a bit and maybe put a little grease on it to let it slide easier.
Thanks guys!
« Reply #8 on: April 25, 2009, 07:53:07 am »
Make sure the choke is opening all the way and the fast idle screw is set properly.
