Author Topic: block lift question  (Read 12785 times)
Offline gold84gmc
block lift question
« on: April 23, 2009, 09:03:02 pm »
i bought 2" blocks for my leaf springs, is there anything special to putting these on or is it just take the old u-bolts off and but the block in and put the new u-bolts on
92 buick century custom 3.3L
Offline 4x4orbust
Re: block lift question
« Reply #1 on: April 23, 2009, 09:29:25 pm »
that's pretty much all you have to do,   check your brake lines and make sure they won't get over-extended, check your vent lines, enjoy your new lift!
« Reply #2 on: April 24, 2009, 07:52:23 am »
Check and see if the block is tapered. One the larger blocks, one end is thinnner than the other for pinion adjustment. I dont know about the two in blocks. The smaller end is the front of the block and goes toward the front of the truck.
Offline gold84gmc
« Reply #3 on: April 24, 2009, 10:30:01 am »
ok i just tried to put them on and the u-bolts arent big enough they dont fit over the axle tubes. anyone know where i could get a cheap 2" block set that would fit it?....i have the 14 bolt rear end
« Reply #4 on: April 24, 2009, 11:01:56 am »
You need new u-bolts, not different blocks.
Offline gold84gmc
« Reply #5 on: April 24, 2009, 12:25:45 pm »
ya i know...but buying just the u-bolts is probably almost as expensive as a kit with the blocks
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: April 24, 2009, 01:33:02 pm »
I got a 1.5 block kit for my 14 bolt from superlift.  I think it was $70 or so for the kit of Cast Iron Blocks and u-bolts.  Looked like good quality stuff.  2 inchers should be around the same price.
Offline gold84gmc
« Reply #7 on: April 24, 2009, 03:09:07 pm »
thats a little more than im planning on spending because i only paid $30 for mine
« Reply #8 on: April 24, 2009, 09:57:08 pm »
Ive seen the ubolts sell bu themselves at regular parts stores like Autozone, Oreilys, NAPA, etc./ try them
« Reply #9 on: April 25, 2009, 01:32:41 am »
Autozone sells the u- bolts i want to say for 15 bucks but i cant remember. now what you doing up front to the coils?
Offline gold84gmc
« Reply #10 on: April 25, 2009, 08:05:52 am »
i might wait a little while but i wanted to put coil spacers because if i put the 1ton coils itll be an even rougher ride (its a rough enough ride as it is)....any suggestions on what i should do?
« Reply #12 on: April 26, 2009, 12:41:07 am »
I've heard of the spacers working them self loose, haven't seen it but I've heard of it, the 1 ton springs well that will be a fun ride. i would save up for the lifted coils i don't know were to get them from but they have to be made but then your still looking at a rough ride so you might as well go for the 1 ton. those ubolts should be good take your old ones to the zone match them up make sure they will fit and get them
Offline gold84gmc
« Reply #13 on: April 26, 2009, 08:08:04 am »
i found some 1 ton springs online for $144, is this a good price or would i be able to find them cheaper?
