Author Topic: hard starting  (Read 4368 times)
Offline gold84gmc
hard starting
« on: April 24, 2009, 07:28:10 am »
after my truck is warmed up it starts fine but if i let it cool down a little bit it starts hard, i have to push the gas a little bit and it takes a longer than it should to crank over....any suggestions on why its doing this?
92 buick century custom 3.3L
Re: hard starting
« Reply #1 on: April 24, 2009, 07:38:04 am »
Give us more info on your truck. Do you have a carburetor? Which one?
Offline gold84gmc
Re: hard starting
« Reply #2 on: April 24, 2009, 08:20:17 am »
350 with a q-jet carb
Re: hard starting
« Reply #3 on: April 24, 2009, 08:41:47 am »
Do you get a puff of black smoke when it does start? I'd check for leaking well plugs.
Offline gold84gmc
Re: hard starting
« Reply #4 on: April 24, 2009, 10:27:47 am »
no black smoke but when it does start hard blue smoke comes out...which means oil, i already know the valve seals are bad but would those cause it to start like that?
Re: hard starting
« Reply #5 on: April 24, 2009, 05:10:01 pm »
If the fuel bowl drains into the intake #1 your plugs will foul and #2 your fuel bowl is empty which means a harder start. Pull the carb off and seal the well plugs with some JB weld and see what happens.
Offline gold84gmc
Re: hard starting
« Reply #6 on: April 24, 2009, 07:44:21 pm »
im not to good with carbs so do you have any pics or steps on how to do it?
Re: hard starting
« Reply #7 on: April 24, 2009, 11:02:54 pm »
Just google quadrajet well plugs and you'll probably find 100 articles on how to.
