Author Topic: RE:FUEL PUMPS 101:  (Read 8955 times)
Offline Stewart G Griffin
RE:FUEL PUMPS 101:
« on: April 26, 2009, 03:28:48 am »
1) What is the return line really for?
2) If, in a situation, where the carb only wants or needs say 4-5 lbs, but the pump puts out 5 1/2 to 7lbs., would having a return line help the situation assuming the carb float can hold back the 5 1/2 to 7lbs?
3) If, say, we switch to a more appropriate pump---one that puts out 3-5lbs AND HAS NO RETURN OUTLET ON IT, can we/should we plug the return line to the tank with no adverse side effects?
Re: RE:FUEL PUMPS 101:
« Reply #1 on: April 26, 2009, 03:31:12 am »
i think return lines are mainly for emissions probably wrong but that what it seams to me
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #2 on: April 26, 2009, 10:43:48 am »
My 78 had heavy duty emissions on it.  Basically the only emissions device it has is the pcv valve and the heat riser valve.  It didn't come with any kind or return line.  It's not a problem for mechanical pumps.
Offline Cowman85
« Reply #3 on: April 26, 2009, 10:48:28 am »
i'm running a red holley electric (97gph, 7psi) with no return line and it seems to be running pretty rich, i do smell gas sometimes so i could imagine i would benefit from hooking mine back up...
86 C20 350/TH400 LWB
80 C2500 350/Muncie SM465 *gone to heaven* LWB
98 Malibu 3.1 V6
86 S10 L99/4L60E
« Reply #4 on: April 26, 2009, 12:09:06 pm »
You should be running a fuel pressure regulator. Something like this
Offline Cowman85
« Reply #5 on: April 26, 2009, 05:25:06 pm »
ya i've been looking for one but no one seems to carry them around here, i might have to order one off the net.
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline HAULIN IT
« Reply #6 on: April 26, 2009, 10:14:45 pm »
Stew, I'll try to help with your questions.
 1) A return line can have a couple purposes depending on the application. The one is to keep the pump cool, a constant flow of fuel can not heat up like fuel that is stagnant. Also, the pump will work easier/likely longer if it is not "dead heading"...try sticking you finger over a bicycle tire pump & pumping...it will be difficult, then go, this is what a fuel pump does at idle...up to the bypass & open, up tto the bypass & open.
 2) Yes, this is another reason for a return line. The vehicle needs X fuel pressure while making power, but at idle it needs very little. The second part of question # 2 isn't correct, "assuming the float can hold back the 5 1/2-7 psi", the needle will not see 5 1/2-7 if that's what the pump is making. If the return line is big & not restricted in some way...you won't have any fuel pressure. The return line bleeds it off, so to answer your question, yes it will "kill" the excess pressure if done correctly.
 3) For this reason, If you have a pump that only puts out 3-5 psi, then yes you would not want to use a return line, if you do...it would need to have a very small hole, just enough to accomplish #1, if that is your desires. If you have a lower pressure pump, the return can be plugged without problems, in fact, it may eliminate one. Lorne
« Reply #7 on: April 26, 2009, 10:44:52 pm »
So, plugging the return line would not cause the fuel tank to colapse?
« Reply #8 on: April 26, 2009, 11:17:44 pm »
The fuel tank vent is what allows tank pressure to stabilize not the pump return.
http://www.secondchancegarage.com/public/535.cfm
« Reply #9 on: April 26, 2009, 11:19:09 pm »
Ok, cool.
Offline HAULIN IT
« Reply #10 on: April 26, 2009, 11:20:54 pm »
No Stewart, that couldn't happen. Think of it this way...the return line was BRINGING fuel back at low pressure. Taking this away has no side effects. If in a worse case mythbuster mode & you made an extreme return line (shop air supply numbers - 130 psi, maybe) the tank would SWELL, not collapse. A vacuum is what would make it collapse, even the vent being plugged won't make it collapse...not run & hard to fill maybe. Lorne
« Reply #11 on: April 26, 2009, 11:38:50 pm »
Ok, cool again.
P.S.
In my (desperate)research, i came across this awesome online video course concerning fuel pumps and fuel systems.  i think you get a certificate and a hat if you pass the test.  Not that i care about that---i'm just saying.  i don't have time to watch it but here it is:
http://www.fueldst.com/FDSD/Player.html
2)What fuel pressure should a Rochester 2G be getting?
