73-87 Chevy & GMC Trucks
Will a 74 Cab fit a 76 frame?
Topic: Will a 74 Cab fit a 76 frame? (Read 6305 times)
Fast_suv
April 28, 2009, 08:53:58 am »
I found a nive 74 Cab, no rust.
I have a 76 truck now...
would i fit?
Anything needed?
1976 Chevy K10 1/2 ton
Tuff country 6" lift kit
3" body Lift
16/35/15Lt Super Swamer Boggers
--Under Construction--
choptop
Extended cab fanatic
Re: Will a 74 Cab fit a 76 frame?
April 28, 2009, 09:03:51 am »
Should fit no problems. Id replace the cab mounts while I was at that point.
Fast_suv
April 28, 2009, 09:06:21 am »
thats where the body lift things go right?
(new to trucks lol)
3" body Lift
ccz145a
April 28, 2009, 09:17:50 am »
If your truck is a 4x4 or manual trans or both, you need to think about the trans tunnel. It has to match or you need to transfer your tunnel to the donor cab.
Fast_suv
April 28, 2009, 09:49:44 am »
Cool, i have a spare one of those from another truck
3" body Lift
April 28, 2009, 10:14:14 am »
As CCZ stated if the 74 cab is a 2WD cab you may have clearance problems on you 76 4x4. We need more information to answer this correctly.
April 28, 2009, 10:21:12 am »
If you have a body lift it may have no clearance issues.
