Author Topic: wich heads to use  (Read 15177 times)
Offline hogwild
wich heads to use
« on: April 28, 2009, 12:52:37 pm »
baught a motor today that has what looks like vortec heads but the guy said they are not. heres casting #14096217, motor number is10243880. what do i have?. and should i use these heads or the 305 heads i have with 194 valves
1986 sb 406 ci
2003 mud buggy 1300 hp 528
if my wife askes it was only fifteen bucks
Re: wich heads to use
« Reply #1 on: April 28, 2009, 01:40:48 pm »
They are not Vortec heads in the term of the popular aftermarket Vortec heads.
Those are 87-up 72 degree center bolt heads.  1.94/1.5 valves 64cc.  It is the GMPP equivalent to the factory L98 Iron head (14011083),  It was used on the 300hp/350 and 330/350 crate motors.  They were also used on HO marine motors.
The engine PN is a 1986-99 Gen I HD block.   Applications include the 330hp ZZ4 Crate motor block, so based on that info it sounds like the motor is a ZZ4 Crate engine.
Are you planning on putting these on the 406, if so they are WAY better than 305 heads.
Offline Blue 82
« Reply #2 on: April 28, 2009, 05:45:06 pm »
The 6217 were used in a lot of Marine applications too
The exhaust valves were sodium filled and used a 3/8" stem instead of the standard 11/32"
I had to replace on of those sodium filled valves on a friends boat. $53 from the dealer....(for 1 valve)
Offline hogwild
« Reply #3 on: April 28, 2009, 06:08:53 pm »
captkaos i am not wanting them for my 406, i am building another 350 for a oval track truck i will use this block and rotating assembly, just not sure wich heads to use. my 305 heads i already have are pocket ported 194 valves instaled, good springs etc... i thaught if those were vortec heads they would be better. alsoo have solid cam 524 lift that goes with the 305 heads.guy i baught the 305 heads from said on 10.5 - 1 350 these heads and cam would make 400 hp ,dont know if i believe him though. wich way would you go
1986 sb 406 ci
« Reply #4 on: April 28, 2009, 08:10:39 pm »
most 305 heads are good for boat anchoring. I'd go with the other ones.
Offline fitz
« Reply #5 on: April 28, 2009, 08:50:49 pm »
Doesn't the ZZ4 have aluminum heads on it?
Offline hogwild
« Reply #6 on: April 28, 2009, 09:35:47 pm »
these ones are defenetly not aluminum.  looking at exaust ports and exaust valves the 305 heads are way bigger intake manifolds are on both motors so cant look at int valves.ville if i use other ones what do you recomend for a cam to make this thing rev dont need bottom end for oval racing
« Last Edit: April 28, 2009, 09:39:46 pm by hogwild »
1986 sb 406 ci
« Reply #7 on: April 28, 2009, 09:54:16 pm »
What size valves are in those heads? Can you measure them?
Offline hogwild
« Reply #8 on: April 28, 2009, 10:34:36 pm »
305 heads have 1.94-1.6somthing.  other heads i dont know i would have to take them off motor to measure 1.94-1.50 i would guese smaller than the 305 heads for sure. just measured valves on the 305 heads they are 1.94-1.6 little bit of porting done down in pocket by valves, now wich ones would be better
« Last Edit: April 29, 2009, 01:04:00 pm by hogwild »
1986 sb 406 ci
« Reply #9 on: April 29, 2009, 05:34:22 pm »
305 heads have poor flow qualities compared to a 350 head I would use the ones off the new block, they flow well with some port work.
Offline hogwild
« Reply #10 on: April 29, 2009, 06:13:35 pm »
why would anyone go through al of the expence of having bigger valves put in 305 heads if they are poor performers? these heads must have cost alot of money to modify, i got them with another motor so it doesnt matter to me, i will use the crate engine as is . is it posible that the 350 i have with 305 heads could make 400 hp? cam  is a solid  518-536 lift,278-288 dur, 10.5-1 comp, stock iron intake, quadrajet carb,headers, i dont believe it , but guy that biult engine swears its a good 400 hp
1986 sb 406 ci
« Reply #11 on: April 29, 2009, 08:59:40 pm »
Because either someone was stupid and believed that all the power they could make would come from a smaller combustion chamber or they were just trying to improve the breathability of their junk heads. Nevertheless $ is better spent on better heads.
« Reply #12 on: April 30, 2009, 04:27:49 pm »
I really can't come up with a better answer than that...
Offline hogwild
« Reply #13 on: April 30, 2009, 07:30:48 pm »
what cam you guys recomend for this crate motor?, i allready have headers , performer intake , would think a cam upgrade should find me some power. for oval track truck 3000-6000 rpm
1986 sb 406 ci
« Reply #14 on: April 30, 2009, 10:58:45 pm »
If it is a ZZ4 motor, I would use the one in it.  What are your goals?
