Wheels & Tires
wheels - what years are interchangeable?
Topic: wheels - what years are interchangeable? (Read 15693 times)
p7387
April 30, 2009, 08:57:44 am »
concerning "5 lug wheels" on our 73-87 trucks
What other body years are interchangeable?
for example
88--up
67-72
60-66
thanks
Re: wheels - what years are interchangeable?
April 30, 2009, 11:59:25 am »
Just trucks > 71-99 5 lug 2WD 1/2 Ton trucks.
choptop
Extended cab fanatic
April 30, 2009, 03:17:24 pm »
I think all 6 lugs are interchangable
4x4 in our trucks, two wheel drive pre70, 99 newer?
p7387
May 01, 2009, 12:55:46 am »
thanks-
what is the diff. pre 71?
why the difference for 67-70, arent they the same as 71?
choptop
May 01, 2009, 07:24:40 am »
The earlier trucks were all 6 lug whether 2wd or 4wd.
velojym
November 29, 2009, 08:56:39 pm »
My C10's 5 lug wheels are from a '90s model truck.
edited to add: I just bought tires today, and picked up an identical spare... it came from a '97 Tahoe, evidently right before they went to 16" rims.
Last Edit: January 11, 2010, 07:54:27 pm by velojym
Flamingbig10
November 30, 2009, 11:47:45 am »
also 1/2 vans and most full size cars from pre 96
y2k_harley
November 30, 2009, 04:03:25 pm »
Watch the backspacing, 88 and up may be different. I have a set of 95 rallies for my truck. Since I put on the Bell Tech spindles they rub on the lower ball joint. The older 15X6 1/2 rallies clear fine.
Jim Rockford
Banned
December 10, 2009, 08:26:51 pm »
astro vans got the 5x5 pattern along with 91-96 caprices, including the Impala ss with the 17 inch wheels.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
RMC_SS_LDO
February 17, 2010, 08:35:32 pm »
Quote from: Flamingbig10 on November 30, 2009, 11:47:45 am
Resurrecting an older thread, but I've been looking at a set of 16" wheels from an '86 Camaro. I know zero about the offset or center hub spacing requirement so wondering if anyone is familiar with them and if they'd work without issues.
Respectfully,
Allen
choptop
February 17, 2010, 08:40:35 pm »
I believe the camero wheels are 5X4-3/4 pattern so they wont work without adapters.
RMC_SS_LDO
February 17, 2010, 08:48:25 pm »
Thanks for the quick reply...
If I am reading what I have correctly, the stock lug pattern for our 1/2 ton trucks is 5X5 (vice 4.75); Am I on the right track?
choptop
Reply #12 on:
February 18, 2010, 06:56:58 am »
Yes that is correct. Our trucks are 5x5, GM car small pattern is 5x4.75, the 6 lug is 6x5.5, and I think the 8 lug is 8x6.5. someone correct me if Im wrong please.
RMC_SS_LDO
Reply #13 on:
February 18, 2010, 05:05:57 pm »
Thanks for the info!
This place has already saved me from a lot of costly errors. Hopefully your collective patience will continue as I learn more about fixing WonderTruck up!
/r
Allen
Wheels & Tires
