Author Topic: wheels - what years are interchangeable?  (Read 15686 times)
Offline p7387
« on: April 30, 2009, 08:57:44 am »
concerning "5 lug wheels" on our 73-87 trucks
What other body years are interchangeable?
for example
88--up
67-72
60-66
thanks
Re: wheels - what years are interchangeable?
« Reply #1 on: April 30, 2009, 11:59:25 am »
Just trucks > 71-99 5 lug 2WD 1/2 Ton trucks.
« Reply #2 on: April 30, 2009, 03:17:24 pm »
I think all 6 lugs are interchangable
4x4 in our trucks, two wheel drive  pre70, 99 newer?
Offline p7387
« Reply #3 on: May 01, 2009, 12:55:46 am »
thanks-
what is the diff. pre 71?
why the difference for 67-70, arent they the same as 71?
« Reply #4 on: May 01, 2009, 07:24:40 am »
The earlier trucks were all 6 lug whether 2wd or 4wd.
Offline velojym
« Reply #5 on: November 29, 2009, 08:56:39 pm »
My C10's 5 lug wheels are from a '90s model truck.
edited to add: I just bought tires today, and picked up an identical spare... it came from a '97 Tahoe, evidently right before they went to 16" rims.
« Last Edit: January 11, 2010, 07:54:27 pm by velojym »
Offline Flamingbig10
« Reply #6 on: November 30, 2009, 11:47:45 am »
also 1/2 vans and most full size cars from pre 96
Offline y2k_harley
« Reply #7 on: November 30, 2009, 04:03:25 pm »
Watch the backspacing, 88 and up may be different.  I have a set of 95 rallies for my truck.  Since I put on the Bell Tech spindles they rub on the lower ball joint.  The older 15X6 1/2 rallies clear fine.
Offline Jim Rockford
  • Banned
« Reply #8 on: December 10, 2009, 08:26:51 pm »
astro vans got the 5x5 pattern along with 91-96 caprices, including the Impala ss with the 17 inch wheels.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline RMC_SS_LDO
« Reply #9 on: February 17, 2010, 08:35:32 pm »
Resurrecting an older thread, but I've been looking at a set of 16" wheels from an '86 Camaro.  I know zero about the offset or center hub spacing requirement so wondering if anyone is familiar with them and if they'd work without issues.
Respectfully,
Allen
« Reply #10 on: February 17, 2010, 08:40:35 pm »
I believe the camero wheels are 5X4-3/4 pattern so they wont work without adapters.
Offline RMC_SS_LDO
« Reply #11 on: February 17, 2010, 08:48:25 pm »
Thanks for the quick reply...
If I am reading what I have correctly, the stock lug pattern for our 1/2 ton trucks is 5X5 (vice 4.75);  Am I on the right track?
« Reply #12 on: February 18, 2010, 06:56:58 am »
Yes that is correct. Our trucks are 5x5, GM car small pattern is 5x4.75, the 6 lug is 6x5.5, and I think the 8 lug is 8x6.5. someone correct me if Im wrong please.
Offline RMC_SS_LDO
« Reply #13 on: February 18, 2010, 05:05:57 pm »
Thanks for the info!
This place has already saved me from a lot of costly errors.  Hopefully your collective patience will continue as I learn more about fixing WonderTruck up!
/r
Allen
