Author Topic: rebuilt 305 wont run  (Read 15821 times)
Offline Layne
« on: May 02, 2009, 09:20:21 pm »
just put my 305 in and got it to turn over.  We moved the distrubutor left and right and found a spot that it would start to run and then hiccup a fireball out of the carb. anywhere else and it would shoot fireballs out of the headers.  I then took out the distributer and rotated it 180 degrees and... nothing.  It's got a lunati bracket master 2 cam, gear drive, non computer dis, edelbrock rpm air gap nascar intake and a holley 750 i got for 100 dollars. (I couldn't talk my girlfriend into letting me get a eddi 500 for 350 dollars.) Any ideas? I think it might be the cam timing, but i checked it 9 times before i put the motor in my truck.
Offline Layne
Re: rebuilt 305 wont run
« Reply #1 on: May 02, 2009, 09:39:00 pm »
77 c-10 82 305 86 700r4
« Reply #2 on: May 02, 2009, 10:35:29 pm »
Sounds like you were off a tooth. Put it on TDC compression and reinstall the distributor.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: May 02, 2009, 10:37:35 pm »
or....double check spark plug wires to ensure installed in proper order...18436572
Offline Layne
« Reply #4 on: May 02, 2009, 10:38:35 pm »
can't you compensate for the ign timing by twisting the dis? I'm kinda confused with the tooth thing. Sorry. lol
Offline Layne
« Reply #5 on: May 02, 2009, 10:39:03 pm »
checked and quadruple checked
« Reply #6 on: May 02, 2009, 10:41:55 pm »
No, So start over and line up tdc compression.
Offline Layne
« Reply #7 on: May 04, 2009, 04:50:53 pm »
set the distributer in and timed it at 8 degrees and it still won't run.  Is it supposed to be at 0 or 8 when you first start out?
« Reply #8 on: May 04, 2009, 05:17:10 pm »
Drop it in with #1 on TDC and leave some room for advance,
Set timing at 10 degrees and work you way around from there.  It will probably hit around 12 degrees for a stock motor.
Offline exilous
« Reply #9 on: May 04, 2009, 08:36:07 pm »
I had that same problem in my 85 blazer 305 it was 1 tooth off but if i cranked the distributor way out it would just barely run...then uhm well it just stopped and wouldnt run anymore...I was still learning about it the day i got it home i figured out the whole tooth off thing after the engine died.
Offline Layne
« Reply #10 on: May 04, 2009, 09:24:06 pm »
rockers were too tight! lol loosened them up and I got compression. should have checked the compression earlier! Thanks for the help though.
Offline 1976Scottsdale
« Reply #11 on: May 04, 2009, 09:59:19 pm »
Gotta watch those.  Otherwise that bracket master will be coming right back out.  Its not even fun til the lobes flatten so bad that the valves start opening on the back side of the lobe... still get nightmares... Mommy!?!
Offline Layne
« Reply #12 on: May 06, 2009, 04:20:49 pm »
today i went to break the cam in and i started out at 80 oil psi and 4min later i had 20... I killed the truck and looked underneath and I've got all five quarts on the ground!!! So i looked around and found the front of the intake is leaking a litte oil and so is my rocker cover.  I looked behind the motor and oil is everywhere.  Which would be more likely- the back of the intake or the rear main?  If it is the rear main do I have to pull the motor or can i get the pan out without pulling my engine?
Offline eventhorizon66
« Reply #13 on: May 06, 2009, 04:26:36 pm »
Did you use the cork end seals on the intake or RTV?  I use TheRightStuff RTV (about a 3/8" bead) and have no issues with leakage.  Grab a new set of intake gaskets and try that first.  If you do have to drop the pan, you can do it with the engine in the truck no problem, I did this not too long ago.
« Last Edit: May 06, 2009, 04:29:43 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline Layne
« Reply #14 on: May 06, 2009, 04:34:51 pm »
i used a cam change kit from mr gasket i think. edelbrock said not to use the rubber end seals on the intake and just glob a bead through there. I used rtv red.
