Author Topic: 1987 R10 Driver  (Read 537719 times)
Online Captkaos
Re: 1987 R10 Driver
« Reply #255 on: July 15, 2014, 10:39:51 pm »
Sunday, April 13th, 2014: Pulled out the Retrosound Model 2 and began the installation.  Got all the wiring soldered put in the new speakers from RetroSound (forgot to take pics of the rear) and plugged it all in..
Online Captkaos
Re: 1987 R10 Driver
« Reply #256 on: July 15, 2014, 10:42:29 pm »
Tuesday, April 15th, 2014: Took a pic of the display on the RetroSound Model 2 during the day.
Online Captkaos
Re: 1987 R10 Driver
« Reply #257 on: July 15, 2014, 10:53:08 pm »
Sunday, April 27th, 2014: Got all of the AC vents out to get them put back in.  (For got the pic of the one going to the driver in all of these..)
Pulled the deteriorating foam off and leaned all the vents up with Super Clean
Picked up some insulating foam tape from Lowes.   and reinstalled the new foam on.
Online Captkaos
Re: 1987 R10 Driver
« Reply #258 on: July 15, 2014, 10:56:44 pm »
Wednesday, May 7th, 2014:  Picked up new rear brake lines from Advanced Auto.  PN PAJ-330
Also installed a new AC diverter valve connector to replace the broken one...
« Last Edit: July 15, 2014, 11:00:35 pm by Captkaos »
Online Captkaos
Re: 1987 R10 Driver
« Reply #259 on: July 15, 2014, 11:03:25 pm »
Monday, May 12th, 2014: Test fitted the AC duct in the truck.  Found I am going to have an issue on the way I routed the ECM wires.
Mounted the RetroSound microphone behind the A-pillar for hands free talking on my cell
Online Captkaos
Re: 1987 R10 Driver
« Reply #260 on: July 15, 2014, 11:07:22 pm »
Thursday, May 15th, 2014: Driving home found a huge leak in the floorboard from the heater core.
Saturday, May 17th, 2014: pulled out the old heater core and cleaned up the AC box and reinstalled the new one, didn't get a chance to upload those pictures yet.  Coming soon.
Online Captkaos
Re: 1987 R10 Driver
« Reply #261 on: July 15, 2014, 11:09:51 pm »
Sunday, May 18th, 2014: Started bending the lines for the rear disc brake setup.
Online Captkaos
Re: 1987 R10 Driver
« Reply #262 on: July 15, 2014, 11:15:18 pm »
Monday, May 18th, 2014: Got the tabs I had made for the brake line locks bent like I wanted them and had a buddy weld them on.
Got the tabs welded where I needed them
Flared the new lines and attached the new 1972 C10 front brake hoses to the D52 Wilwood calipers.  Now it is read to be installed...
Online Captkaos
Re: 1987 R10 Driver
« Reply #263 on: July 15, 2014, 11:19:30 pm »
Friday, May 30th, 2014: Driving home and close to home something didn't seem right pulling into the driveway.  As I put it in reverse and backed up and then went to go back in drive I realized something wasn't working.  Turned the truck off and found that the shift linkage had fell off.  Spent the next day puttting it back on.  It was also at this time I found a slight oil leak coming from who knows where...
Online Captkaos
Re: 1987 R10 Driver
« Reply #264 on: July 15, 2014, 11:23:56 pm »
Wednesday, June 18th, 2014: Driving home and close to home something didn't seem right again.  As I was pulling into the gas station to fill up,  (since I haven't routed the gas fill yet, I am limited on where I can fill this thing up) I noticed something fishy going on with the front end like the whole side of the truck was moving.  I carefully drive it the mile home and discovered that the shims were all gone from the passenger side.
Had to go out of town for a week so the Suburban pulled daily duty for a while.
Online Captkaos
Re: 1987 R10 Driver
« Reply #265 on: July 15, 2014, 11:27:11 pm »
Monday, June 30th, 2014: Drove the truck very carefully from my house to the alignment shop and dropped off my lower control arm bushings that I had and had them replace both upper and lower bushings and get an alignment on the truck.  While I was there I took this pic from underneath.
Online Captkaos
Re: 1987 R10 Driver
« Reply #266 on: July 15, 2014, 11:30:04 pm »
Sunday, July 6th, 2014: Started back on getting the AC duct modified for missing the harness so the wires won't be pinched.  Heated up the duct to put an indentation in it.  Did this a few times but need to get the new Dash in before I can find the proper clearance.
Online Captkaos
Re: 1987 R10 Driver
« Reply #267 on: July 15, 2014, 11:33:50 pm »
Sunday, July 6th, 2014: Pulled out the new OE style vinyl skinned dash and started fitting the trim panel and AC ducts to it.  The middle duct required a little trimming to get the vent in.  Used a 3/8" nut driver, razor and heat gun (just in case)
Online Captkaos
Re: 1987 R10 Driver
« Reply #268 on: July 15, 2014, 11:36:15 pm »
Monday, July 14th, 2014: Test fitted the new dash in the truck, had to trim up the sides and rear of the dash but still need to tweak the top duct to allow the dash to sit flush, more to come.
Online Captkaos
Re: 1987 R10 Driver
« Reply #269 on: July 15, 2014, 11:38:16 pm »
Tuesday, July 15th, 2014: And now for the best worst news...
As of today, the turbos are making a metallic sound.  I am not sure what it is yet, but I am wondering if the cartridge is bad...  Going to have to pull them off while I am on vacation the following week.
