Members Rides
1987 R10 Driver
20
21
22
23
26
Topic: 1987 R10 Driver (Read 538128 times)
Re: 1987 R10 Driver
Reply #300 on:
January 02, 2015, 05:51:46 pm »
Monday, September 22nd, 2014:
Took the truck out for its maiden voyage. Had a grinding noise that I couldn't find coming from the rear.
Last Edit: January 03, 2015, 09:35:25 pm by Captkaos
Re: 1987 R10 Driver
Reply #301 on:
January 03, 2015, 09:42:14 pm »
Sunday, September 28th, 2014:
After a couple more drives I finally narrowed the noise (other than the gear whine on accell) to the Calipers grinding on the rotor. When I bought these brackets from Captain Fab there were mentions of this happening but I had these for a while. Emailed Captain Fab about it and he told me to take pics. In my haste of getting it installed I never noticed the difference in the rotors. I ordered a replacement set and asked them to order 3, you will see why soon...
Here is where it was grinding.. (passenger side)
This is the Passenger side rotor:
Notice the Drivers side, not grinding
Re: 1987 R10 Driver
Reply #302 on:
January 03, 2015, 09:54:29 pm »
Monday, September 29th, 2014:
Rotors showed up and I went to pick them up. I initially just had them open the box, compared my measurement was the same and emailed Captain Fab my findings and told him I would give him measurements on my setup. Went to lunch and then went back to the store and asked to see and measure all of the rotors. I found 2 different sized as before. 7.3/8" and 7.1/2"
This 7.3/8" rotor, this matched my side that didnt rub:
This 7.1/2" rotor:
All 3 rotors (from Autozone) had the same part number and manufacturer/company.
Customer Service from Captain Fab was top notch. He modified the bracket measurements for future cuts along with sending me replacement brackets free of Charge.
Re: 1987 R10 Driver
Reply #303 on:
January 03, 2015, 10:03:48 pm »
October 8, 2014:
dropped the truck off at
http://hensonperformance.com/
to get the truck dyno'd again after changing the turbo's, rear axle swap to 3.42 gears and limited slip, lowering and 4 wheel disc swap.
Now I can drive it and beat on it some without worrying about a bad batch of gas. It has recently developed a oil leak that appears to be the rear main so I am not going to push this motor. Plan on getting the other 6.0L pulled down and put back together and swap it out. It made 457.9@5100rpm and 505.5lb/ft@4250rpms on 7.7lbs.
Re: 1987 R10 Driver
Reply #304 on:
January 03, 2015, 10:04:22 pm »
Thursday, October 23rd, 2014:
Received the replacement brackets from Captain Fab
Saturday, October 25th, 2014:
Removed and reinstalled the replacement brackets along with finding an axle seal leak on the drivers side tube. yeah.
Brocksdad1
Re: 1987 R10 Driver
Reply #305 on:
January 04, 2015, 07:57:24 pm »
Your thread is great. I wish I had done mine like yours.
God,Family,Fishing,Cardinals baseball,Chevy trucks
Re: 1987 R10 Driver
Reply #306 on:
January 05, 2015, 09:31:58 pm »
Thanks! it feels never ending...
Brocksdad1
Re: 1987 R10 Driver
Reply #307 on:
January 05, 2015, 09:32:27 pm »
I know the feeling
FearNoMan78k10
A project turned into a complete rebuild
Re: 1987 R10 Driver
Reply #308 on:
January 05, 2015, 10:15:09 pm »
Those are some high speed brakes you have.... Very nice.... Impressive truck and build that's for sure ! Capt your builds are always top notch .... Seriously .....
78 k10 4x4
Re: 1987 R10 Driver
Reply #309 on:
January 11, 2015, 07:55:15 pm »
Thanks!
squarebody.biz
Iann128
Re: 1987 R10 Driver
Reply #310 on:
April 21, 2015, 09:52:13 pm »
Just read all the way through this and wow is all I can say. My son and I just pulled the 305 and th350c in prep to put at 5.3 in his 84. Got some good tips from this post.
Ian
roundhouse
Re: 1987 R10 Driver
Reply #311 on:
April 25, 2015, 10:06:42 pm »
Nice write up !
Re: 1987 R10 Driver
Reply #312 on:
August 12, 2015, 11:42:25 am »
Thanks guys. I have been really distracted but as of June the truck looks like this now. AND I can fill the truck up anywhere. Had to do this before I went on Power Tour More updates to come.
NASTY-LSX
Re: 1987 R10 Driver
Reply #313 on:
August 16, 2015, 03:39:44 pm »
WOW, Great build. Love how quiet it is!!. 1 question. How did you make your SS wheels fit? Adapter?
Re: 1987 R10 Driver
Reply #314 on:
August 17, 2015, 06:36:53 am »
NASTY-LSX, the Impala cars with HD suspension share the same bolt pattern with the 2WD trucks up to 1999.
20
21
22
23
26
Members Rides
1987 R10 Driver
