Author Topic: elbr. 1450 trouble and 203 not goin into and h/l lock  (Read 4067 times)
Offline maw454
« on: May 10, 2009, 09:47:50 pm »
i am having trouble getting my sec. to open on my carb. its a 1450 mech. choke/sec. i needa help!
also im havin troubles getting my 203 to go into high and low lock any ideas?
Offline TexasRed
Offline martin79
Re: elbr. 1450 trouble and 203 not goin into and h/l lock
« Reply #2 on: May 13, 2009, 08:39:20 pm »
  I would install a couple of screws in carb linkage so that secondaries open manually,but i don`t think you will be happy with results.
  On the shift problem,my brother once welded a section of steel angle iron to the shifter,making it longer and providing more leverage so he could muscle it into gear........................the truck ran for a while.....................sitting now..................
« Reply #3 on: May 13, 2009, 08:52:03 pm »
The secondaries aren't allowed to open if the choke isn't opened fully. You will see a stop mechanism preventing the secondaries from opening. Make sure the linkage is routed correctly to allow the to open when the choke is open.
AS far as your transfercase shifting, check the linkage and lubricate it first.
Offline Russ130
« Reply #4 on: May 16, 2009, 11:43:56 am »
Don't forget to adjust the shifter linkage too.
