Blazers/Jimmys
79 jimmy tailgate window wiring help
Topic: 79 jimmy tailgate window wiring help (Read 14249 times)
exodus138
May 11, 2009, 07:18:09 pm »
i recently purchased a 79 jimmy and the rear window switch is missing i found it in a junk box in the rear i need to figure how to wire it. the switch has 3 prongs there are only 2 wires coming from the rear window a blue and a white one. the prongs on the back of switch are in uniform alignment with the center raised higher im guessing its in nutreul. do i hook the two wires up and leave the center empty or do i run a ground to the center wire? all help will be appreciated
Re: 79 jimmy tailgate window wiring help
May 11, 2009, 07:35:00 pm »
Piece of cake
Click this link to view the full size
Click Here
⌠ŻŻŻŻŻ' [☼===☼]
exodus138
May 11, 2009, 08:22:51 pm »
so ihook center wire to a pink comin from fuse block? i'm horrible with diagrams
May 11, 2009, 08:39:27 pm »
Yes the pink wire is protected by a ckt breaker in the fuse block.
⌠ŻŻŻŻŻ' [☼===☼]
exodus138
May 14, 2009, 01:38:18 pm »
i searched through this mess called wiring... no pink wire comin from fuse panel... not surprised everything is split probably going to need a new harness. messy lazy previous owners! short on cash right now can i run a new wire to it? if so where on the panel should it run to?
May 14, 2009, 03:04:21 pm »
Do you have the rear power window circuit breaker in your fuse panel?
⌠ŻŻŻŻŻ' [☼===☼]
exodus138
May 14, 2009, 03:31:51 pm »
how can i find it? do you know where it's located?
May 14, 2009, 04:10:21 pm »
In the fuse box. Take a picture of your fuse box and post it.
⌠ŻŻŻŻŻ' [☼===☼]
BLAZERRR77
October 02, 2009, 02:35:57 am »
humm the only thing i can think of is hard wiring it like an acc switch not really sure i was thinking about putting eletric back window in my 77 blazer just wire it up with a some wire that has a fuse built into it if you will get what i mean by this but it sounds good to me haha all it is ...is and up /down switch with power going to it
October 02, 2009, 07:41:37 pm »
⌠ŻŻŻŻŻ' [☼===☼]
Blazers/Jimmys
