Author Topic: Lug nuts/Impala SS Wheels  (Read 9641 times)
Offline three8six
« on: May 15, 2009, 08:34:02 pm »
I know my truck need 1/2 20 lug nuts, but it seems the stocks are to short to install the Impala SS stock wheels on it because when I attempt to tighten them I run out of room before it goes all the way in. I was wondering do I just need to get taller/longer lug nuts(which seems to be the way to go) or is there another problem going on? FYI it's a 1986 Fullsize c10 2wd if that helps at all?
Re: Lug nuts/Impala SS Wheels
« Reply #1 on: May 15, 2009, 08:44:57 pm »
Doorman 1/2" -20 lugs from Autozone.
Offline three8six
« Reply #2 on: May 15, 2009, 09:06:09 pm »
Part #?
« Reply #3 on: May 15, 2009, 09:12:17 pm »
Well, I got them from a long time ago...  The factory lugs with the open ends are exactly the same.
Offline three8six
« Reply #4 on: May 15, 2009, 09:20:24 pm »
Thanks....basically though all I need is 1/2 20 that is longer than the factory correct?
« Reply #5 on: May 15, 2009, 11:54:51 pm »
or you just ask the parts guy for lug nuts for a 96 impala SS and he should have them behind the counter or give you a number for the isle they are in if you want aftermarket looking ones
Offline HAULIN IT
« Reply #6 on: May 16, 2009, 08:27:24 am »
Irish, I'm thinking the '96 Impala lugnuts are metric...I could be wrong though. Lorne
« Reply #7 on: May 16, 2009, 10:12:47 am »
Impala SS Lugs are metric, won't work..
I dug up a receipt, for 5 on mine are 611-094.1 from Autozone. The factory replacement lugs work just the same and they have open centers, which I prefer.
Offline three8six
« Reply #8 on: May 16, 2009, 03:40:22 pm »
I solved it I got new ones like 1 inch compared to the half inch ones I had. I just can't put them on or remove them with an impact socket due to the clearance but other than that they are great and thanks for your help Capt. I love the way they look on my truck(I'd post pictures but its still so far from being done I'll start posting pictures once I install the new doors and the one peice kits.
« Reply #9 on: May 16, 2009, 11:37:48 pm »
lol that would be a small problem wouldn't it
