Author Topic: 78 to 86 Engine Swap (350)  (Read 3722 times)
Offline Trukk
« on: May 25, 2009, 02:48:47 pm »
The bottom end is coming apart in my 78. I found a 1986 350 with 55k miles on it for a good price. Will this be a bolt in swap? Trans is the original TH400.
Mike
Offline fiyaweed06
Re: 78 to 86 Engine Swap (350)
« Reply #1 on: May 25, 2009, 02:51:02 pm »
it should drop right in!
« Reply #2 on: May 25, 2009, 03:47:29 pm »
As long as the 86 is an auto trans too. If not you will need a flex plate for it. The 78 is a two piece rear main seal. The 86 is a one piece rear main seal.
