Author Topic: Where to find a good rearend for my k-5 blazer  (Read 18541 times)
Offline Stowburb
« on: May 26, 2009, 09:39:08 am »
Hey Guys,
 I need a good used rearend for my K-5 blazer. The one in my truck took a dive, and i have never rebuilt a Diff. before.
I was thinking i would find a used one cheap and just swap it out. I have a 3.42 gear in mine.
 Having trouble finding one around here, and the one i did find had 200,000 miles on it and they want my first born son for it!
Thanks,
Chris
« Last Edit: May 26, 2009, 10:04:35 am by VileZambonie »
Re: rearend for my k-5 blazer
« Reply #1 on: May 26, 2009, 10:03:33 am »
Max Used Auto Parts USA-NC(Hickory) Request_Quote 1-800-346-8755   Has one for $400. Try Craigslist. What exactly failed in yours?
You can also check the classifieds here if you are a site supporter.
Offline 80stepsideguy
Re: Where to find a good rearend for my k-5 blazer
« Reply #2 on: May 26, 2009, 10:54:39 am »
To bad you arent close by this be perfect for you..
http://spacecoast.craigslist.org/pts/1180945835.html
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline Stowburb
« Reply #3 on: May 26, 2009, 11:30:49 am »
knocked a few teeth off the ring gear.
Offline oldredtruck
« Reply #4 on: May 26, 2009, 01:45:46 pm »
Dans Gears on EBAY
that guy has all kinda stuff... bought the locker in old red from him...excellent feedback
85 shortbed...She digs it...
Offline exilous
« Reply #5 on: May 26, 2009, 05:00:45 pm »
Hey stow I tried to PM awhile back to see how that bracket worked out for you but your mailbox is full. Too bad you dont live closer i could hook you up with a rearend of mine, heh heh mine are 3.08 ratios though. send me a PM when your mailbox is empty.
« Reply #6 on: May 26, 2009, 11:27:16 pm »
is your k5 4x4 or 4x2?
Offline Stowburb
« Reply #7 on: May 27, 2009, 07:23:16 am »
Ray, the brackets i got from you work great. Thanks again for looking out for me.
« Last Edit: May 27, 2009, 08:15:51 am by VileZambonie »
Offline Benjy_26
« Reply #8 on: October 05, 2009, 08:40:50 pm »
By definition, a K 5 is the 4x4.
As far as replacing the rear end, I'd reconsider.  If all that happened is that the ring gear stripped some teath, I'd just replace the gears.  If you have your hear set on replacing the axle, I recommend cruising locally and finding a K20 or 30, preferably one with a salvage title or no title, or even one with a blown engine or tranny.  You probably won't pay much and you'll be able to upgrade both axles to beefier units.  I'm in the process of doing the same with my '76 K5.  I purchased a '83 K20 for $600.  This netted me some much needed interior parts, a FF 14 bolt, a 28 spline 10 bolt front, and a NP205 (goodbye NP203!).
« Reply #9 on: October 06, 2009, 12:03:25 am »
then whats the 4x2 called  ;) we all ready been over this a while back i thought a 4x2 would be c5 but its not its a k5
Offline Benjy_26
« Reply #10 on: October 06, 2009, 12:05:26 am »
According to GM's nomenclature, it is a C5.  The C in the VIN stands for 2wd, the K for 4wd.
« Reply #11 on: October 06, 2009, 12:15:25 am »
well then wouldn't the k5 =k5000  for like a 1 1/2 ton or something like that lol
Offline Benjy_26
« Reply #12 on: October 06, 2009, 11:02:44 am »
It should, if you think about it.  GM does some wacky things.
« Reply #13 on: October 06, 2009, 11:21:00 am »
All Blazers are labled as K5's regardless of their drivetrain configuration.  K5 = Blazer and can be had in 2WD or 4WD from 73-82.
By GM's Nomenclature they are C10/C1500 or K10/K1500.
