Author Topic: Rebuilding a Quadrajet  (Read 4399 times)
Offline fast823
« on: May 28, 2009, 02:56:31 pm »
Going to rebuild my quadrajet before it goes back on my in progress 383 and was wondering if I should go to a electric choke and put a new float in. Also any tips or other things I could do. I got the standard carb rebuild kit. Thanks,
Re: Rebuilding a Quadrajet
« Reply #1 on: May 28, 2009, 03:05:11 pm »
Jb weld the well plugs. A new float is a good idea along with electric choke. See how it runs from there after you rebuild it.
Offline 82gmc3/4ton
« Reply #2 on: May 30, 2009, 11:36:13 am »
I rebuilt a Q-jet a few years back. Definitely better with the new float and choke. The kit I bought had pretty good instructions in the box. Also make sure you clean all gunk out and think about using a better filter. Q-jets have a filter thats on a spring. If it gets clogged it by passes the filter.
Offline fast823
« Reply #3 on: May 31, 2009, 01:44:06 pm »
Am I going to have to rejet due to the bigger motor?
« Reply #4 on: May 31, 2009, 02:06:28 pm »
You won't know til you try it.
