Author Topic: NP 208 seal questions  (Read 8222 times)
Offline 82gmc3/4ton
« on: May 28, 2009, 06:17:05 pm »
Before I bolt up my transfer case I would like to replace the seals. While looking up front seals I noticed R-Auto have a double lip seal and different shaft sizes. Has anyone used this double lip seal? Is there a way to tell what shaft I have or do I have to mic it? Also I noticed that the rear seals come in either a rubber coated seal or nitrile. Is one better than the other? If there is anything else I should know before throwing this thing back in let me know. Thanks
Re: NP 208 seal questions
« Reply #1 on: May 28, 2009, 06:44:13 pm »
Just get whatever seal replaces the one you have unless the shaft has deep scoring. Lube them with ATF or trans gel before you put them in too.
Offline 82gmc3/4ton
« Reply #2 on: May 30, 2009, 11:15:50 am »
Would the double lip seal help with deep scoring? Thanks for your help Vile.
