Author Topic: My 1980 SWB Project Truck  (Read 156383 times)
Offline Grim 82
Re: My 1980 SWB Project Truck
« Reply #60 on: February 28, 2011, 07:04:17 pm »
On my 82 the hood release cable is also pretty much just draped across the inner fender. Not sure about the radiator shroud, but I know the radiator mounting brackets and the supports are different from an 80 to an 86.
Offline eventhorizon66
« Reply #61 on: February 28, 2011, 07:10:09 pm »
That truck is super slick!
'85 C10 SWB 350 700R4 TKO600
Offline 1980c10
« Reply #62 on: February 28, 2011, 08:55:14 pm »
It looks as though the clutch/brake pedal assembly is identical as far as bolting into the truck. If I am right I will just have to drill the mounting holes for the clutch cylinder.
The one on the left is the hydraulic linkage assembly..on the right is the manual linkage assembly
Not my truck but this the mounting location from the inside of the cab
I also grabbed the brake booster and master cylinder from the 85 as it is a better looking set up than my own.
I will buy a new clutch cylinder, slave cylinder and just build a line to connect the two.
Offline 1980c10
« Reply #63 on: March 13, 2011, 01:03:39 am »
update:
clutch pedals were a direct bolt in from the 85, had to remove the steering column to do this.
drilled three holes for the clutch cylinder and installed along with the reservoir and line.
everything under the hood is painted and going back together.
With the battery installed-post toward front of vehicle. I have run my battery cables through the header panel and inside of the frame
(hidden from sight) I used a 78" pos cable and a 36" neg cable for those who may want to do this
I installed the heater box with the '94 blower motor with slight modification and the fan blade from the '80.
tomorrow I will install the steering column, brake booster, master cylinder and lines from the master cylinder.
I really need a wiring diagram for the engine (1980) I've searched and couldn't find one anyone have a link?
Offline Grover 1
« Reply #64 on: March 13, 2011, 10:14:32 am »
If you're into cleaning up under the hood, you might consider an electric fan...
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline 1980c10
« Reply #65 on: March 14, 2011, 12:23:38 am »
This will probably happen later this year. Just not yet I am pretty busy with a new job starting and still trying to quit my old job and I want to have this back on the road by the end of next month and have a long way to go.
Offline Tad.
  • '86 SWB
« Reply #66 on: March 14, 2011, 07:43:37 pm »
Holy jeebus! Beautiful truck! I am jealous, man!
Offline 1980c10
« Reply #67 on: March 14, 2011, 08:38:17 pm »
Here are some updated pics as of last weekend.
this the master cylinder and booster out of the '85
Offline 1980c10
« Reply #68 on: March 14, 2011, 08:49:33 pm »
btw I found the wiring diagrams
Offline 1980c10
« Reply #69 on: March 23, 2011, 10:01:26 pm »
I decided today to go with an electric fan, I will install it between the radiator and grill.
I had a snow day from work today and have gotten a few things done.
I modified power steering bracket to work with the headers. Had a ton of trouble with this; someone had broken bolt on the brackets on the pump from my parts truck and had drill and hammer them off.
here is a pic after I painted it and modified the bracket that bolts to the header.
replaced the brake lines from the master cylinder
gear reduction starter and spark plug wires routing
homemade bracket for the wires
looking for opinions on this; it is the inline 6 radiator shroud stretched for the bigger radiator. Should i finish this or make something else?
here is another pic of the engine, I will order a new power steering pully and the cone for the water pump
Offline figure843
« Reply #70 on: March 23, 2011, 11:00:08 pm »
Sweet truck! Why a 94' blower motor? Does it blow harder? If so I want to do the same to my 84'
1984 SILVERADO LWB 350/400
1988 SILVERADO K5 BLAZER 350/700R4/NP208/3:73/6"RC LIFT/38.5/15/15 BOGGERS
Offline 1980c10
« Reply #71 on: March 23, 2011, 11:21:22 pm »
They do. I run each motor off the battery; the 94 seemed more than double than the originial 80.
Offline figure843
« Reply #72 on: March 24, 2011, 01:10:43 am »
Cool! I'll have to check that out.
Offline thirsty
    • Suitor's Garage
« Reply #73 on: March 24, 2011, 07:07:05 am »
Excellent work on the plug wires!
Offline 1980c10
« Reply #74 on: March 24, 2011, 03:34:20 pm »
Thanks, It was actually cheaper and easier than running them over the valve covers and making them look good.
My next dist cap will be a "corrected firing order" cap, that way I will be able to bring the wires to each side cleanly.
Also I decided not to run a hood cable at all, I will show that set up when I take pics of my electric fan/cooling set up.
The fan will be a "puller"
My headlight wiring is done and so are the battery cables
I am still looking for opinions on the radiator shroud
