Author Topic: 305 swap question  (Read 15054 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
305 swap question
« on: May 29, 2009, 10:42:18 am »
I have a 87 truck with a 305 with a bad rod knock.  Also have a 305 from a 79 el camino laying around that runs great. Can I just put the tbi intake, distributor, etc onto the old motor, drop it in and call it a day or is there going to be more to it? Jeremy
Offline eventhorizon66
Re: 305 swap question
« Reply #1 on: May 29, 2009, 10:54:14 am »
The intake won't just bolt on without some modification to the two center bolt holes on each side.  They are at a different angle on the 87-95 heads.
'85 C10 SWB 350 700R4 TKO600
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: May 29, 2009, 10:57:52 am »
Crap I forgot about that. How about if I put the 87 heads on the older block, any other problems?
« Reply #3 on: May 29, 2009, 12:42:01 pm »
No problems if you switch intake and heads.
« Reply #4 on: May 29, 2009, 04:13:45 pm »
Elongating the holes isn't a big deal. Get a carbide burr and stick it in your die grinder. You'll be done in minutes.
« Reply #5 on: May 29, 2009, 04:18:12 pm »
You are going to run into a dipstick-left side exhaust manifold issue between the 79 block and 87 stock truck manifolds.  Please disregard if you run headers....
Offline Stewart G Griffin
« Reply #6 on: May 29, 2009, 04:31:38 pm »
Exactamundo on the dipstick thing;  i ended up making a "sleeve" out of a spare dipstick tube and then screwing in a flattop hexbolt to keep everything sealed up.
Current plan is to drain the oil every week to measure how much is in the pan----will refill if the oil looks clean.
Will post pictures as soon as the whole fiasco is over and taken care of.   We're almost there.
« Reply #7 on: May 29, 2009, 05:27:39 pm »
I actually worked out a solution after I decided to go with headers.  GM made an adapter plate to convert the exhaust manifolds on the left side so you could put all the bolts in and seal it from leaking.  I was just going cut the adapter plate where the dipstick tube would normally come through and then bend the tube straight.  Then I found a deal on a complete dual exhaust system all the way back with headers included.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #8 on: May 30, 2009, 10:51:46 am »
Thanks zieg and stewart I had not thought of the dipstick either and no I'm not running any headers.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #9 on: May 30, 2009, 11:42:29 am »
Also the 87 motor has a knock sensor where as the 79 motor does not.
« Reply #10 on: May 30, 2009, 12:00:16 pm »
The knock sensor just screws into the coolant jacket. It makes no difference. There are several different dipsticks you can use.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #11 on: May 30, 2009, 02:59:15 pm »
I gave that knocking 305 away today and the guy thinks he is going to roll a new bearing in that rod and put a new oil pump in and be ok. Wonder how long before the new bearing spins too.
« Reply #12 on: May 30, 2009, 09:33:04 pm »
60-90 seconds
« Reply #13 on: May 30, 2009, 11:26:40 pm »
i think there is/was a pan available that has the dipstick going directly into the pan---not from the block into the pan.
This pan was stock (maybe) on some gm cars but am not sure----haven't had time to do research---so i decided to do my seal up plan.
There may also be aftermarket and/or custom pans available with "stand alone" dipsticks.
You can also always modify a stock pan---my suggestion is to take a, say 4"x6" piece of lexan, and make a "window" on the side of the pan so you can see how much oil is in the pan.  Will provide more detailed plans later.  Or have a dipstick going directly into the pan by drilling a hole etc.
« Reply #14 on: May 31, 2009, 09:00:07 am »
I just did one of these swaps and just had to get an $11 dollar dipstick and tube. Problem solved. There are also universal dipsticks out there that you can use.
