Author Topic: questions about lift  (Read 7693 times)
Offline sk8erdude36
« on: May 31, 2009, 05:26:33 pm »
so i have a 74 k20 and i would like to put an 8'' lift and a 3'' inch body lift. ive been reading and it sounds like you cant do an 8'' lift without getting a new driveshaft. do i need a new shaft or will s spacer do the trick. and whats the largest size tires i can get on this thing?
Re: questions about lift
« Reply #1 on: May 31, 2009, 09:07:56 pm »
You should be able to clear 40"s no problem. What do you mean spacers?
« Reply #2 on: May 31, 2009, 11:41:38 pm »
with 8" you will need new shafts with 6" you sometimes need a little mod pretty much due to joints binding up. do you plan on cutting your fenders? buddy of mine only had 4" on his blazer but he cut the fenders with 38's
Offline 79K20
« Reply #3 on: June 01, 2009, 11:37:42 am »
Do you mean a driveshaft spacer? Never heard of one, but that sounds like a bad idea to me. Just spend the $$ and have a driveline shop extend your shafts. I had both my driveshafts extended a few months ago for like $150.
« Reply #4 on: June 01, 2009, 11:56:49 am »
You can't use a spacers on a GM truck.  You need longer driveshafts.
Offline sk8erdude36
« Reply #5 on: June 01, 2009, 07:29:48 pm »
alright well i think im gonna go with a 6 inch lift instead. 1-because of price and 2-i dont want to have to mess with drive shafts. so 36 or 37 sizes tires shoudl fit??
Offline oldwhity
« Reply #6 on: June 01, 2009, 08:27:21 pm »
Don't forget to get longer brake lines. Also, you may need longer shafts with a 6" too. I can't remember but someone will chime if you do.
Also, you'll need to loosen the filler neck on the gas tank(s) and cut the bottom of your fan shroud for the body lift.
Rob G.
81 Chevy K20 4x4 LWB stepside
« Reply #7 on: June 02, 2009, 01:33:39 am »
like whity said you need to mod a couple things to get the body lift in and extended brake lines swaybar drop if you want one and 38's should fir with no problem theres a chart i had that broke down what you need to do to get tires to fit i think it was made by 4wheeler found it in one of there mags.
