Author Topic: 2WD cab on 4WD frame. Trans tunnel/transfer case question.  (Read 6590 times)
Offline fitz
I've read all of the past threads I could find on this subject and considered the options but still have 1 question. Would it matter which transfer case I use when I swap cabs. I will be running a turbo 350 trans and have 203/205/208/241 transfer cases to pick from.
Just wondered if any of these would offer a  height advantage so I could avoid using a body lift or modifying the trans tunnel. Thanks.
                                   Fitz
Re: 2WD cab on 4WD frame. Trans tunnel/transfer case question.
« Reply #1 on: June 03, 2009, 07:32:55 pm »
The 208 and 241 are smaller and have a better linkage system
Offline fitz
« Reply #2 on: June 03, 2009, 09:09:48 pm »
I'm thinking about using the 241. Any guesses if it will clear the floorpan without using a body lift? I will use a transfer case drop down kit to gain a little clearance. I'm just trying to avoid a body lift or hacking up the floor.
« Reply #3 on: June 03, 2009, 09:37:30 pm »
I would rather build a new trans tunnel than use a body lift personally. I'm not sure if it will clear.
Offline fitz
« Reply #4 on: June 03, 2009, 09:56:15 pm »
I hate body lifts too. The 2wd cab is an 82. The 4x4 is a 81 and it has a bolt on trans tunnel so I can always use that on the 2wd cab if I need to.
« Reply #5 on: June 03, 2009, 11:33:16 pm »
Isn't the front output shaft is on the wrong side of the 241?
I would use the 205 if you have, and bolt the old floor section into the new cab.
Offline fitz
« Reply #6 on: June 04, 2009, 05:25:00 am »
The 89-91 blazers/suburbans use a 241. It looks real similar to the 208. I think it just has some minor internal changes. The driveshafts/shifter/crossmember all interchange.
« Reply #7 on: June 04, 2009, 06:04:07 am »
Oh yeah forgot about those!!
