73-87 Chevy & GMC Trucks
Mystery Orb
Topic: Mystery Orb (Read 5473 times)
CreativeNotice
Mystery Orb
June 04, 2009, 08:30:25 am »
So mounted to the firewall, just behind the jack mount, in the far driver's side corner, is a small orb with one vacuum hose going to it and no outlet. Any idea what it is. My only guess is some kind of dissipation enclosure for the vac system.
C20 '85 350eng
Re: Mystery Orb
June 04, 2009, 11:55:00 am »
Vacuum reserve canister for vacuum operated accessories such as your heater controls.
⌠ŻŻŻŻŻ' [☼===☼]
CreativeNotice
Re: Mystery Orb
June 04, 2009, 11:57:50 am »
So what's its exact function. Does it just stabilize pressure in the lines?
eventhorizon66
Re: Mystery Orb
June 04, 2009, 12:20:49 pm »
Its purpose is to generate alot of speculation and rumor from onlookers. Actually, I believe "Mystery Orb" is its proper name. So, lucky guess.
It stores a reserve vacuum to operate all the little HVAC vents, flappers, and doodads.
Last Edit: June 04, 2009, 12:40:13 pm by eventhorizon66
'85 C10 SWB 350
700R4
TKO600
ccz145a
Re: Mystery Orb
June 04, 2009, 01:13:40 pm »
...so if your accelerating when you want to change from max to bi-level you won't have to wait until your foot is off the throttle.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: Mystery Orb
June 04, 2009, 02:02:46 pm »
when i read the title of this thread "Mystery Orb", i expected to see a ghost in the truck
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
kenf729
Re: Mystery Orb
June 04, 2009, 04:15:35 pm »
And just to be sure there is an outlet on the bottom going into the cab to the enviorment contorls...if not you have a vacuum leak...
BigBadJohn
Re: Mystery Orb
June 06, 2009, 01:15:58 am »
I too was wondering this. I saw it in a camaro I just picked up and figured it was an emissions thing like the charcoal canister
CreativeNotice
Re: Mystery Orb
June 08, 2009, 08:43:38 pm »
ah, very helpful thank you.
Mystery Orb
