Author Topic: Brake help  (Read 6838 times)
Offline grinder1989
Brake help
« on: June 05, 2009, 08:24:38 pm »
I have an 83 3/4 ton 2wd.  When I called the parts store to get calipers, they asked me if I had a JD6 or JD7 brake system.  I looked all over the truck and couldn't find the option codes.  I'm fine on the back brakes, I know how to measure drums haha.  Which caliper do I need and how do I know which one to get?  Thanks guys.  :)
Sundown Authorized Dealer, Akron OH
Re: Brake help
« Reply #1 on: June 05, 2009, 09:25:48 pm »
Did you look on the spid label in the glove box?
Offline oldwhity
Re: Brake help
« Reply #2 on: June 05, 2009, 09:36:24 pm »
If you get to that "point", just take your caliper to the store and compare.
Rob G.
81 Chevy K20 4x4 LWB stepside
Re: Brake help
« Reply #3 on: June 06, 2009, 01:06:25 am »
if you know how to measure the drums then why not do it? thats how they tell them apart on the autozone computer. or are you just saying you don't want to take the drums off thats why your looking for the option code?
Offline grinder1989
Re: Brake help
« Reply #4 on: June 06, 2009, 01:37:28 am »
There's a label in the glove box, but no option codes.  There is one stuck to the inner fender but no codes for brakes.  FYI, I'm only talking about the calipers.  There are two styles and I can't have my truck sitting in my garage waiting for a part to get ordered, I want to do it all in a day.   I don't care what drums I have on the back because I can measure them and find the parts I need.  The caliper is not as easy to figure out.
Re: Brake help
« Reply #5 on: June 06, 2009, 05:42:55 am »
what i was getting at is if you ask a parts store probably autozone for rear shoes then there question what style breaks do you have they will give you a measurement of the rear shoes and you go by that that should tell you what style breaks you have but since you don't want to do it that way does your master cylinder look like any of these top two are for jd6 and jd6 bottom is for the 7
or you can look at the caliper not the location and angle of the break line fitting
"7"
"6"
this parts a guess but it makes sense since the style 7 seams to be the bigger style than the rear shoes should be the 13" ones while the 6 style should be the 11" ones and there are more than two diffrent styles just all that matters for this app is if its 6 or 7
good luck buddy
« Last Edit: June 06, 2009, 05:44:36 am by Irish_Alley »
Offline Marc
Re: Brake help
« Reply #6 on: June 06, 2009, 08:03:54 am »
You could get both and return the one that isn't right when you take the core back.
Offline grinder1989
Re: Brake help
« Reply #7 on: June 06, 2009, 12:12:30 pm »
Thanks guys.  :)
Re: Brake help
« Reply #8 on: June 06, 2009, 11:21:39 pm »
now thats too easy why would he do that
Offline grinder1989
Re: Brake help
« Reply #9 on: June 07, 2009, 02:01:43 am »
Less crap I'd have to deal with.  If I know what to look for, I'll always know what to look for  ;D
Offline farmallgray
Re: Brake help
« Reply #10 on: June 17, 2009, 11:21:43 am »
The JB6 system will have 11-5/32" rear drums and the JB7 has 13" drums. That is the easiest way to tell which system you have.
1979 K-20 350/TH400
