Author Topic: Grinding Control Arms  (Read 4541 times)
Offline Grover 1
« on: June 08, 2009, 09:48:21 pm »
I just had a three inch drop kit installed on the front end of my 78 Silverado, my 15 inch rims now scrape in somewhat tight turns.  I wouldn't mind going to 16's (tire guys suggestion) but don't have the $$ for rims and tires right now.  Is there anything wrong with either grinding a bit on the control arm lip or putting a 1/4 to 1/2 inch spacer behind the wheel.  I would only use a spacer if there was enough threads on the lugs to safely do so.  Also finding 16" 5 hole rally with a 3-3/4 inch backspace isn't looking to easy, anyone have any sources with that?
Thanks in advance,
Grover
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Re: Grinding Control Arms
« Reply #1 on: June 08, 2009, 10:11:26 pm »
I generally grind them where they hit.
Offline ms4972
« Reply #2 on: June 08, 2009, 10:47:05 pm »
I agree with Capt..  Grind them where they hit.
