Author Topic: are any of these worth the price  (Read 6586 times)
Offline HeAvYChEvY!
  • DoWnWiTdAsIcKnEsS!
    • HeAvYChEvY!
« on: June 11, 2009, 06:03:42 pm »
All For Small Block Chevy / Chevrolet
CHROME OIL PANS
Moroso Chrome Oil Pans, All Brand New
Have 2 Low Profile w/ Kickout, both Driver Side Dipstick.
$150 each
INTAKES
Have 1 - Weiand 5984 Tunnel Ram Manifold, Blue - $200
CRANK / CRANKSHAFTS
Have 1 - Forged-steel, large journal, and 10/20 - 350/5.7L $100
Have 3 - cast-steel, large journal, and std/std - 350/5.7L $50 each
FLEXPLATES
SBC 400 Combo OEM 8" Harmonic Balancer and 14.125" 168 Tooth Flexplate, both Externally Balanced - $100
Have 3 - Flexplates, 12.875" 153 Tooth - $10 each
Have 2 - Flexplates, 14.125" 168 Tooth - $10 each
BLOCKS which one of these blocks is the best to build?
Ref : CID : Bore : # Main Bolts : Year : Casting# : Suffix# : Notes : Price
1 400 Std 2 1974 330817 T0628CSU Bare Block $300
2 400 Std 2 1976 330817 T0708CSX Complete Short Block $400
3 400 Std 2 1975 330817 T0403CTU Bare Block $300
4 400 0.03 4 1972 3951511 - Complete Short Block - FACTORY 4-BOLT MAIN !!! $600
5 400 0.03 2 1973 3951511 T0124CSA Bare Block Fresh Machine Work $500
6 350 Std 4 1982 14010207 V0913ACM Bare Block $150
7 350 0.03 4 1979 3970010 K0121TBC Bare Block - Most Head & Main Studs $150
8 350 Std 4 1970 3970010 V0826TBC Bare Block $150
9 350 0.06 4 1974 3970010 V0815TMM Bare Block - Fresh Machine Work, Rehone 2 $300
10 350 Std 2 1970 3970010 V0622CNV Complete Short Block $200
11 350 Std 4 1970 3970010 V0729TBZ Complete Short Block $300
Offline HeAvYChEvY!
    • HeAvYChEvY!
Re: are any of these worth the price
« Reply #1 on: June 12, 2009, 09:57:24 pm »
bump
« Reply #2 on: June 13, 2009, 12:50:05 am »
Are you trying to sell this stuff or buy something in particular?
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #3 on: June 13, 2009, 07:42:55 am »
im trying to buy the best block to build and engine out of to replace the 305 that is my 78! also if any of the other parts are worth the money i will buy them too. this guy placed this ad locally and my motor is tired so its time to think about an upgrade.  im looking to build an engine that will get between 375 and 425 horse off of pump gas. thank you!
« Reply #4 on: June 13, 2009, 09:44:01 am »
I wouldn't buy anything from this guy unless you really want a 400.
You can buy a roller vortec 350 in need of a rebuild for $150-$400 bucks complete.
Offline HeAvYChEvY!
    • HeAvYChEvY!
« Reply #5 on: June 13, 2009, 09:54:07 am »
reasons? which 400?
« Reply #6 on: June 13, 2009, 10:14:00 am »
Reasons I wouldn't buy any of his stuff?
Do you need a chrome oil pan for $150 bucks?
You can get a stock replacement for $30 bucks or one of these if you need more capacity http://www.kmjent.com/cart/product.php?productid=797
No need for a tunnel ram
Used cranks, flexplates and balancers are not necessary unless you need a specific part. If you're planning on a rebuild just buy a complete engine unless you are looking for a 400. If I were going to buy one I would want a complete engine
