Runs worse after tune-up
Topic: Runs worse after tune-up (Read 15677 times)
Jay2D2
June 12, 2009, 08:05:50 am »
I changed the plugs and wired in my truck the other night and ir ran good for a little afterwards but then it started running rough, almost like an internittent miss but not quite, and then the idle dropped to the point it was barely running and now when I put it in gear she stalls almost immediatly. When I give it gas she rungs good and smooth... the problem just seems to be at idle. I didnt touch the timing or anything on the carb and before the tune up it was not doing this so I dont think its a bad adjustment. I checked for disconnected vacuum hoses and what not but everything looked good.
Now fo rthe truck... its a 1984 C10 with a pre 78 small block not sure 305 or 350 yet. It was originally a straight 6 but was swapped out at one point. I dont know what the emissions components or carb are from. Its a 2 barrel but not sure if its original to the engine or was something newer off another 84 or what.
Any clues?
ccz145a
Re: Runs worse after tune-up
June 12, 2009, 08:13:44 am »
Look for arcing plug wires. Check routing for burned wires. Try taking a plug wire off one at a time and notice changes in idle, when you take one loose and nothing changes you found it.
Jay2D2
June 12, 2009, 08:18:24 am »
Wires are all good and I forgot to mention that the plugs were actually changed about a month ago and it was running ok with them before, I tried soaking the wires down with water while it was running and no changes.
frogman68
June 12, 2009, 08:23:34 am »
Did you happen to knock a vacuum line loose ?
Have you checked the timing ??
Jay2D2
June 12, 2009, 11:54:29 am »
I have not checked the timing yet however I would be surpsied if that was the problem since it did not hppen before and I didnt touch anything to do with the timing.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
June 12, 2009, 12:21:21 pm »
spark plug wire came loose, i bet
Those metal clips have to fit snuggly and you can usually feel it when it clips on the plug, or on the dist. cap. However, they can jump off after a little heat.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
Jay2D2
June 12, 2009, 12:25:08 pm »
Checked the possibilty 3 times, Double checked them all at both ends then tried undoing them completely and putting them back on... no help at all.
ccz145a
June 12, 2009, 12:44:06 pm »
Retrace your steps and look at everything.
Any one of the new parts may have failed. Cap, wire, plug.
Try disconnecting wires one at a time. Once you find the cylinder, get an old wire and put it on and see if that helps. If it does not, then it is a plug or the cap.
Just start putting your old stuff back on methodically, you might find a couple of wires crossed.
Lt.Del
Andy aka:SgtDel
June 12, 2009, 12:54:46 pm »
well if you checked the wires again, I'd next say it may be possible your distributor cap is cracked.....run it at night and see if you see any blue spark where it shouldn't be.
www.HikerMania.com
Jay2D2
June 12, 2009, 01:11:42 pm »
The cap and rotor wernt changed, they are still the same ones that were there before I changed the wires. I have run it in the dark and sprayed down the cap and wires and it didnt change my problem or arc anywhere.
Its not really a miss but more of a very low erratic idle... could be an intermittent miss but its the low idle giving me the troubles
frogman68
June 12, 2009, 01:13:34 pm »
Did you do one wire at a time ? or pull em all ? Check the firing order
Jay2D2
June 12, 2009, 02:08:06 pm »
Firing order is fine. I have not tried them one at a time yet though.
June 12, 2009, 02:29:13 pm »
See if you can turn the distributor. If it's loose reset your timing. If ok pop the cap off and check inside.
Jay2D2
June 12, 2009, 02:43:24 pm »
Distributor is nice and tight, no way it got moved.
When popping th cap off what is it im looking for besides the cap and rotor itself?
I plan on changing the cap and rotor but when I brought the wires home they were out of stock. I dont really think I should change them over just either because Im quite sure the problem isnt one of those 2 pieces. Changing them while looking for something may just cause more headaches
June 13, 2009, 02:38:14 am »
when was the last time you put gas in it?
