Author Topic: Headlight Problem  (Read 3558 times)
Offline chevyman350_82
    • Car domain site...
Headlight Problem
« on: June 12, 2009, 08:30:11 am »
On my 81 c-30 the dim lights work just fine but when brights are on sometimes they flash on and off like not a good connection but as soon as you but it on dim again everything works fine I have looked for ground problems and didnt know if this has happen to anyone or can it be just the dimmer switch?
Re: Headlight Problem
« Reply #1 on: June 12, 2009, 10:33:20 am »
On a 1982 I had did the same.  I replaced the dimmer switch and the problem was gone.  I found a windshield leak corroded the plug and switch.  I later put a 1984 tilt column in it and rewired the dimmer switch to the column.
Offline Donut
« Reply #2 on: June 12, 2009, 11:44:25 am »
I'd look at the dimmer switch first, but don't rule out a busted wire or anything else.  Mine turned out to be the bulkhead connector. (where the harness passes through the firewall)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #3 on: June 13, 2009, 02:37:16 am »
do both lights flash or just one, do they flash when you hit a bump or when ever it feels like it. iv had one flash due to the wires at the bulb being bad
« Reply #4 on: June 14, 2009, 08:24:23 am »
X2 on the dimmer switch.
« Reply #5 on: June 15, 2009, 07:45:58 am »
K. Thanks and yea its both headlights that do it ill go get dimmer switch and see if that works.
