Author Topic: What do yall use to paint your engine blocks?  (Read 28314 times)
Offline Skunksmash
« on: June 13, 2009, 01:07:46 am »
When getting an engine all ready and prep'd up to go in a nice engine bay, most people of course will paint the engine block. My question is,  what kind of paint do most people use to paint it? I get the impression that most people use those spray paint cans that are labeled "High temp engine paint" or something like that. They can be found at any wal mart, oriellys or autozone. I really dont know of any alternatives. Perhaps powder coating or something? Maybe some people buy high temp paint from the paint shop and spray like you would a body paint job? I ask cause i got ahold of an old block that i want to start building up for when my motor finally kicks it. It's already back from the machine shop, a buddy had it all worked over but went another way with something else. So he sold it to me for cheap. Supposedly it originally came out of an oldsmobile, so i am thinking of painting it gold. So what would be the best looking, most glossy, most durable paint to use when painting this block?
Offline BigBadJohn
Re: What do yall use to paint your engine blocks?
« Reply #1 on: June 13, 2009, 01:10:32 am »
At one time I was thinking of rebuilding an engine for a camaro I sold. I wanted to make the entire engine flat black and was considering powder coating it myself. I was told by some guys on a camaro board not to use plastic-based powder coat as it could heat up enough to melt and become liquid
« Reply #2 on: June 13, 2009, 10:33:01 am »
Just clean it VERY good and use rustoleum. High temp rattle can paint is garbage.
Offline 82k5diesel
« Reply #3 on: June 13, 2009, 11:29:59 am »
I agree prep is number 1 important. Doesnt matter what you use if you dont prep and make sure it is clean nothing will stick for very long. Oven cleaner works great. We used the same paint on the block as on the body on my buddys 51 ford and after 6 years still looks great.
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #4 on: June 13, 2009, 12:39:38 pm »
I have used base and clear just like I use on the body and have had great success with it.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Offline Skunksmash
« Reply #5 on: June 13, 2009, 02:17:49 pm »
Sweet. So just take it to the body shop and have them do it. Easy. And probly cheap as well. Kinda weird though, i never thought that just plain old car paint would stand up to that temperature. Do you know if they have to primer it like a car? Or do they just spray on the paint and then some clear?
Offline 1HI4x4
« Reply #6 on: June 13, 2009, 02:38:15 pm »
I primered mine just like the body, everyone said it would discolor around the exhaust but it never did. I'll be painting another one this fall that goes in my current truck.
Offline exilous
« Reply #7 on: June 13, 2009, 10:39:50 pm »
Wow, i never would have guessed rustoleum or regular car paint would work. So I should probably return the cans of high temp engine paint I bought?
Offline Skunksmash
« Reply #8 on: June 13, 2009, 11:27:53 pm »
Anyone else know if you are supposed to use primer?
« Reply #9 on: June 13, 2009, 11:33:21 pm »
I have used a self etching primer on a block before. I have also use Chassis Saver, then sprayed over them both with both single stage acrylic enamel, & High temp spray bomb. All of them have held up good.
Offline Stewart G Griffin
« Reply #10 on: June 14, 2009, 10:12:14 am »
Why paint in the first place?
« Reply #11 on: June 14, 2009, 10:41:39 am »
Protection, appearance, better heat dissipation...
Offline Skunksmash
« Reply #12 on: June 14, 2009, 02:38:38 pm »
I didnt know it helped with heat dissipation, i figured if anything it would help hold heat in.
« Reply #13 on: June 14, 2009, 06:00:47 pm »
Protection against rust?
« Reply #14 on: June 14, 2009, 06:20:52 pm »
yes rust and corrosion protection. A clean painted engine will better dissipate heat.  And of course most of all appearance. I have a nice clean engine in all of my vehicles.
