Author Topic: Where is the tempature sensor located  (Read 9818 times)
Offline treepete
« on: June 15, 2009, 12:24:03 pm »
Hey guys. Now that the oil gauge is working agin, I thought I would go after the tempature gauge, since that is not working as well.
I figure before I ask noob questions like "what makes it work" I thought I would apply some of my previous knowledge to the problem.
 I assume that Ill be needing a new "tempature sensor unit" or something that reads the tempature of the engine and sends it to the gauge.
Can someone tell me where this sensor is located please so I can look for it myself and fix/replace it.
ok thanks,
Pete
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Re: Where is the tempature sensor located
« Reply #1 on: June 15, 2009, 12:27:36 pm »
If it's a small block it'll be on the drivers side head. It's called a temperature sending unit. The sensor is for the computer.
Offline Jay2D2
« Reply #2 on: June 15, 2009, 12:28:37 pm »
If I remember correctly its on the drivers side of the block towards the front with one wire going to it,,, up near the manifold just below the valve cover.
Offline eventhorizon66
« Reply #3 on: June 15, 2009, 01:52:01 pm »
On the side of the driver side head, between the exhaust ports for cyl #1 and #3.
'85 C10 SWB 350 700R4 TKO600
Offline Skunksmash
« Reply #4 on: June 15, 2009, 04:26:33 pm »
Hey eventhorizon, ever see that movie, "Event Horizon"?
« Reply #5 on: June 15, 2009, 05:41:29 pm »
Yep
Offline Skunksmash
« Reply #6 on: June 15, 2009, 06:04:46 pm »
It's horrific.
« Reply #7 on: June 15, 2009, 11:53:38 pm »
like vile said the sending unit is what you need or temp switch it looks like this one
part number should be TU66  at the zone
the sensor thats for ecm looks like this one you don't need it is in the intake
Offline Skunksmash
« Reply #8 on: June 16, 2009, 02:27:52 pm »
Wonder why they don't just use the same exact sensor? Make things easier...
« Reply #9 on: June 16, 2009, 02:29:33 pm »
Because they operate differently and have different resistance values. The NTC sensor is a negative coefficient thermistor.
Offline rustys82
« Reply #10 on: June 16, 2009, 03:41:25 pm »
i love talking negative and positive coefficients
Offline treepete
« Reply #11 on: June 16, 2009, 06:17:59 pm »
lol, ok yeah I see it. thanks for all your help. I like the forum all you guys are super helpful.
1983 Silverado
1999 Yukon Denali
Offline BigBadJohn
« Reply #12 on: June 21, 2009, 12:26:00 am »
This thread will come in handy when Im finally done wiring under the dash and put my freshened up cluster back in :)
