Author Topic: Harmonic balancer question  (Read 3817 times)
Offline exilous
« on: June 22, 2009, 09:40:46 pm »
I'm getting down to the last few things that I might need to replace and may not and my harmonic balancer is one of them. I would assume its the original to the 78 engine, it needs a repair sleeve pretty bad but what I'm worried about is the rubber gaskets that are holding it together. They are pretty dry rotted and heavily cracked. Should I replace the whole balancer or should I just clean it up and put it on? and if I were to replace the whole balancer what kinds should I go with I have no idea what I would need to get. its a 350 4 bolt main. Thanks in advance.
Offline Blue 82
Re: Harmonic balancer question
« Reply #1 on: June 23, 2009, 10:02:48 am »
I like these as a stock or mild performance upgrade
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=6399
« Reply #2 on: June 23, 2009, 10:17:44 am »
Just get a replacement from autozone.
