Author Topic: "hooking up"  (Read 13483 times)
Offline 07montecarlo
"hooking up"
« on: June 26, 2009, 07:33:56 pm »
4'11's with eaton limited,holeshot 3600..
what are you guys doing to get power to the ground efficiently
Re: "hooking up"
« Reply #1 on: June 26, 2009, 10:18:32 pm »
 ??? say again in English...
Re: "hooking up"
« Reply #2 on: June 27, 2009, 07:08:34 am »
4'11's gears, with eaton limited slip,holeshot 3600 stall convertor, in a 1978 chevy truck SWB < short wheel base..
will be a gen VI 454 with 353049 big oval port heads.camshaft is undecided...
what are you guys doing to get power to the ground efficiently...
c'mon you understood me 8) ;D
Re: "hooking up"
« Reply #3 on: June 27, 2009, 10:29:00 am »
Power to the ground efficiently isn't usually done with 4.11's and a 3600 stall.  ;D  Don't know what your trans is. Are you saying you wan't efficiency? Or are you saying for just good traction? Are you street driving this truck? Drag racing? Daily Driver? Give as much info as you can.
Re: "hooking up"
« Reply #4 on: June 27, 2009, 12:00:21 pm »
street/strip....
when complete will be a th400 hughes rebuild steel sprag and such.....
title says it all. how to get the truck to "hook up" get traction,power to the ground,launch,accelerate..
front 60/rear 40 shocks,disabling the sway bar,drag racing tricks..60' times under 2 seconds,traction bars,4 link
what does it take to get the power from the motor through the tranny then driveline into the rear axle
then to the rims and tires and finally to the ground,asphalt concrete,prepped track,street et slicks/radial slicks..
typical modest 500 horse big block gen VI with 049 heads little port work,blending..
Re: "hooking up"
« Reply #5 on: June 27, 2009, 12:14:06 pm »
Well you've already got the posi. I'd run drag radial's on the street.
If you are using leaf spring suspension get a set of these
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=7&Category_Code=7387SUSP
I think the long beds hook better than the shortbeds so go with the caltracs at the least. Since your trans isn't done yet have you considered a trans brake? Is your truck lowered? If so how?
Re: "hooking up"
« Reply #6 on: June 27, 2009, 12:47:26 pm »
is lowered, upper and lowers 3" and 2.5" springs..flip kit in rear..i have seen the traction bars for flip kit..as far as trans brake,mmm dont know that is getting radical and
gets abusive if used wrong but maybe down the road when i can justify it with more ponies and stouter drivetrain, like 9"
Re: "hooking up"
« Reply #7 on: June 27, 2009, 12:52:11 pm »
A line lock is a nice cheap helper  ;)
Re: "hooking up"
« Reply #8 on: June 27, 2009, 12:57:38 pm »
yes i agree...i might depending on how it does with the stall and bars but like agreed a line lock would let me fine tune a launch but the con of that may be leaving some power on the table
Offline team39763
Re: "hooking up"
« Reply #9 on: July 29, 2009, 03:46:34 pm »
Caltracs and sticky tires should help you hook pretty good.
Offline 1980c10
Re: "hooking up"
« Reply #10 on: August 05, 2009, 09:53:38 pm »
it all depends on how you are hooking up now. are there problems? you don't need to fix what isn't broken.
Offline campcrf
  • stroked
Re: "hooking up"
« Reply #11 on: August 06, 2009, 02:21:36 am »
70montecarlo, (I have the same problem)I just got a set of these http://www.competitionengineering.com/catalog/CategoryDisplay.asp?CatCode=13116 for my 81 swb truck and I will let you know how they work....  Does anyone know if these are the right way?....   Hopefully you can help 70montecarlo and i.... (we are running about the same power and truck)
Offline campcrf
  • stroked
Re: "hooking up"
« Reply #12 on: August 06, 2009, 02:22:45 am »
sorry.... I meant "07montecarlo"
Offline nico
Re: "hooking up"
« Reply #13 on: August 06, 2009, 11:00:55 am »
I have really been considering going with the CPP crossmember kit to add the 63-72 trailing arms and coil springs to my 84.  It looks like a nice kit, and there are tons of the older trucks running 9's and 10's on basically stock suspension... Most just add sticky tires, poly bushings, good shocks and maybe an airbag in the right rear spring.  They ride very nice also, compared to our leaf springs.
White 1984 Silverado - Factory Paint, Factory Interior, and only 25k miles...
SOLD - Tan 1984 Silverado - 383, 700R4, Detroit Locker & 3.73's...
