Author Topic: Which Brake System?  (Read 35358 times)
Offline 81Cheyenne
Which Brake System?
« on: June 30, 2009, 08:24:11 am »
I'm rebuilding a 1982 K-24 Camper special.  How do I tell which brake system I have (JB5,JD7,JD6..etc)?
I'm wanting to get rid of the Hydroboost and convert to a Vacuum booster and I need to know which parts to buy. And no, I don't have the code sticker in the glove box. (rats)
thanks.
Offline frogman68
Re: Which Brake System?
« Reply #1 on: June 30, 2009, 08:28:21 am »
If its Hydroboost wouldnt it be Jb8?
Offline 81Cheyenne
« Reply #2 on: June 30, 2009, 08:36:23 am »
Dunno.  I guess that I need to know which system to buy parts for if I want to change over to a heavy duty vacuum type brake booster.
Offline 81Cheyenne
« Reply #3 on: June 30, 2009, 03:24:37 pm »
So, anybody have an opinion on changing a hydroboost to a vacuum boost?
« Reply #4 on: June 30, 2009, 03:37:18 pm »
Just go with the heavy duty brake system.
« Reply #5 on: June 30, 2009, 05:02:45 pm »
JB8 is the 1T brakes, I believe you would have JB7 on a camper special.
JB1 BRAKE, MANUAL, DISC/DRUM, 4300 LBS
JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
JB6 BRAKE, POWER, DISC, DRUM 7200 LBS
JB7 BRAKE, POWER, DISC, DRUM 8400 L85
JB8 8RAKE, POWER, DISC, DRUM 10000 LBS
Personally I would keep the hydroboost.
Offline 81Cheyenne
« Reply #6 on: July 01, 2009, 06:59:55 am »
Is hydroboost that much better than vacuum?  I'm going to have to replace the master cylinder anyway and was wanting to get rid of some of the lines. I'll also have to buy another power steering pump if I keep the hydroboost.
« Reply #7 on: July 01, 2009, 04:01:12 pm »
Better is a vague term.  I just wouldn't remove it just to have Vacuum.
AND on a 3/4T truck you would need the HD booster if you changed it.
Offline BigHemi353
  • Diesel Enthusiast
« Reply #8 on: July 12, 2009, 12:24:13 am »
I have an 86 3/4 4x4. the code for my power brakes in the glove box are 1J55. Would this be JB5? My truck has the 6001-7000gvw brake system.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #9 on: July 12, 2009, 02:35:04 pm »
I looked on my build sheet for my '78 C20.  It has the H.D. Vacuum Powered Brakes
It's listed like this on the build sheet:
  J55  H.D. Power Brakes
=JB7  Vac Power Brakes
On the RPO sticker:
Offline BigHemi353
  • Diesel Enthusiast
« Reply #10 on: July 12, 2009, 02:41:16 pm »
Thanks Chevyrado! You've saved me alot of hair pulling at Autozone! lol
