Author Topic: 208 ???  (Read 4285 times)
Offline 82k5diesel
208 ???
« on: June 30, 2009, 06:40:17 pm »
On my 84 k10  automatic i found a crack in my transfercase and is leaking BAD! Now my transmission is showing way low on the dip stick and i know it is not leaking. Is the fluid going into the transfer and then out the crack?  Do they share oil back and forth?
Re: 208 ???
« Reply #1 on: July 01, 2009, 12:07:38 am »
If the transfer case seal is bad yes it will leak into the transfer case. Sounds like you don't need to bother fixing that seal though since you've got a cracked case. Just pick up a used one.
Offline 82k5diesel
Re: 208 ???
« Reply #2 on: July 01, 2009, 10:44:59 am »
Thanks Vile! I thought there was a seal there just wasnt sure. I just picked up another transfer case last night so i can swap it out today.
