Author Topic: fuel gauge messed up  (Read 8298 times)
Offline gold84gmc
« on: July 02, 2009, 09:03:54 am »
is it normal for the fuel gauges to go above full? because when i fill my tanks up the needle goes above full so i dont know if its actually that full or if theres something wrong with the guage
92 buick century custom 3.3L
Offline Armor
Re: fuel gauge messed up
« Reply #1 on: July 02, 2009, 10:34:30 am »
mine does the same thing, but when its at empty, its really there, so i trust it when its below 1/2 tank, as its usually spot on down in the bottom half.
Offline DnStClr
« Reply #2 on: July 02, 2009, 01:13:30 pm »
Does the gauge react the same way with either tank selected? What does your gauge do when you turn the ignition off? if it drops past "E" then the gauge sounds like it's working ok. The sending units are the culprits that tell the gauge where to go.
Don
87 Chevy Silverado
Offline gold84gmc
« Reply #3 on: July 02, 2009, 03:32:00 pm »
ya thats exactly what mine does it only gets messed up above half a tank
Offline gold84gmc
« Reply #4 on: July 02, 2009, 03:32:51 pm »
yes it does it with both tanks....when the ignition is off it drops past E, one of the tanks and sending units are new
Offline nucknoel89
  • Proud to be Canadian!
« Reply #5 on: July 05, 2009, 10:21:34 pm »
Yeah, I found that out the hard way, went to a buddy's house and I was sitting on "E".  I thought that since my gauge goes past the "F" it must work the same the other way.  Instead, I ran out of gas right in front of his driveway....
Offline gold84gmc
« Reply #6 on: July 06, 2009, 07:04:40 am »
lol thats why i like having 2 tanks
Offline DnStClr
« Reply #7 on: July 06, 2009, 10:09:20 am »
It must be pretty common for the fuel needle to go above full with the tank filled. Mine acts the same way. As long as it's correct as it follows the fuel level downward,towards empty, it's working pretty good. I think what we're seeing at full is the fuel sender reaching its upper limit as the fuel tank fills past it.
Don
87 Chevy Silverado
