Author Topic: Engine stalls when shifting to 2nd  (Read 4933 times)
Offline 82BlazerMan
    • Blazer pics
« on: July 02, 2009, 07:00:02 pm »
Hello all,
At full throttle my Blazer stalls when I hit 2nd gear.  It dives down and then imediatly comes back.  Could this be a choke problem?
82 Blazer
305 ci
700r4
Qjet
1982 Blazer 2WD
305ci
700R4
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Engine stalls when shifting to 2nd
« Reply #1 on: July 02, 2009, 09:34:19 pm »
after five or six minutes of running, your choke should be all the way open.  If it is open then, no, it is not a choke problem.  Sounds like a vacuum leak or something.  Check your vacuum line going to the modulator and where it ties into the intake behind the carb, ensure there is no leak there by spraying WD40 around it during idle and see if rpms go up.
Offline Just-speed
  • 84K10 350/700r4
« Reply #2 on: July 05, 2009, 07:10:46 am »
Hmmmmmmmm      Converter?
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
« Reply #3 on: July 05, 2009, 09:58:35 am »
Sounds like fuel starvation. Check for kinked fuel lines, hoses first.
Offline 82BlazerMan
    • Blazer pics
« Reply #4 on: July 09, 2009, 09:09:34 am »
One other note, it does'nt always do this, but it did it last night.  When I hit second gear at full throttle, it stalled for a split second and came back, then stalled and came back.  This went back and forth about 3 times, each time not as much till the rpm's came up enough to continue.
1982 Blazer 2WD
305ci
700R4
Offline TexasRed
« Reply #5 on: July 09, 2009, 08:55:38 pm »
I'm with Vile, sounds like fuel starvation. Check your fuel filter, the fuel pressure/volume at the carb. When's the last time you changed that filter?
Offline 82BlazerMan
    • Blazer pics
« Reply #6 on: October 07, 2009, 12:12:53 am »
I checked the fuel filter about a year ago.  Ok, I know it's been awhile since I posted, but it runs fine when I stay out of the gas.  I'd like to get into the gas every now and then.  Even with the puny 305 it'll bar the tires hitting second.  I miss jumping on it.
1982 Blazer 2WD
305ci
700R4
Offline TexasRed
« Reply #7 on: October 07, 2009, 06:43:06 pm »
Are you sure the accelerator pump is working correctly? With the engine off, do you get a pump of fuel when you snap the throttle?
Offline 82BlazerMan
    • Blazer pics
« Reply #8 on: October 12, 2009, 02:37:49 pm »
yes
1982 Blazer 2WD
305ci
700R4
