Author Topic: GOOD SETUP???  (Read 4450 times)
Offline str8bloc
  • MISTRESS
GOOD SETUP???
« on: July 04, 2009, 05:03:53 pm »
hey ppl i have an 83 longbed with an 86 350 and a rebuilt th350 i have true duals with 24'' cherrybombs an edelbrock performer carb (1406)accel plugs and coil msd cap and rotor .what else bolt on performance can i get, i have flowtech headers that i need to install and gettin ready to put on a holley street dominatior intake what kinda cam should i use since its a stock motor will the headers make a bunch of difference in sound can i pop my glasspacks?
FaTbOy
Re: GOOD SETUP???
« Reply #1 on: July 04, 2009, 11:27:59 pm »
Your glass packs won't last long anyway. If you are running stock heads don't go over .480" lift
Re: GOOD SETUP???
« Reply #2 on: July 05, 2009, 12:05:27 am »
i cant answer any mod questions except for the pipes like vile said they will burn out you should have a cross over pipe of some sort x or h, and you should also have high flow cats to help with back pressure. where did you come out with your pipes? if you went over the axle then nm on the cats they should be fine but if you came out before the wheels then yes need cats or some sort of back pressure
Offline str8bloc
  • MISTRESS
Re: GOOD SETUP???
« Reply #3 on: July 05, 2009, 09:44:54 pm »
well im gettin ready to add my cherry bomb extreme mufflers behind the glass packs when i add my headers
FaTbOy
Offline cowboy63645
Re: GOOD SETUP???
« Reply #4 on: July 11, 2009, 05:57:13 pm »
Your adding your mufflers behind the glasspacks?  When you put your headers on, put on some sort of balance pipe, either a "h" pipe or an "x" pipe, and then run your exhaust pipe to your mufflers, do away with your glasspacks all together.
