Author Topic: I just installed new spindles, but I may have messed up the ball joint install.  (Read 6864 times)
Offline team39763
I installed new spindles on my 82 C10 yesterday, but noticed the lower ball joint was bad.  I went and bought a new one and asked a neighbor how he replaced his.  He told me just smack it out with a hammer and hammer the new one back in place from the bottom.  So that's exactly what I did.  It only took 2 hits with the hammer and it popped out.  I lined up the new one as best I could and gave it several hard hits from the bottom and checked to see that it felt secure.  Then I put everything back together.  Now after reading in the tech articles, I see that I went about it all wrong.  Is the truck unsafe to ride in?  I can't/won't try to take the control arm out to have the thing pressed in, so that's not an option.
You should use a ball joint press. If you didn't damage the new one don't worry about it.
Ive used a hammer and brass rod all is fine
Offline gold84gmc
cant you use a c-clamp and make it into a custom ball joint press?
92 buick century custom 3.3L
Offline modular93fox
do you know about autozones rent a tool program?
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Offline team39763
Sorry, I hadn't been on here for a bit.  Yeah, I just realized I could rent most of the tools I need from Autozone.
GET IN THE ZONE...AUTOZONE
Offline joesgarage71
  • Wrench
 Yup Big C-clamp and some large sockets
