Author Topic: Does this look right to you? Need quick feedback.  (Read 10098 times)
Offline SUX2BU99
« on: July 09, 2009, 02:37:31 pm »
I had my oil pan leak 'fixed' on Tuesday. I don't think they got it right. I had a Fel-pro 1-piece gasket put in. I drove my truck about 60 miles each way yesterday to have my posi done and I could smell burnt oil when I came off the freeway. I figured it was just spilled oil burning off from when they removed the pan. But when I put cardboard under my truck last night just to see if the leak was fixed, I found a bunch of drips this morning. Not happy!  >:(  And I washed the undercarriage last night with SuperClean just to be certain it wasn't old oil drips.
I crawled under there this morning to find a rather wet undercarriage. Oil and water, since it was raining yesterday and I had washed under there. But pretty oily too. I found at the back of the block what looks to be an incorrectly installed gasket. It looks bulged out from the oil pan and appears to be rubbing against the crank flange (at least I think that's the crank flange). It looks like it's either ripped or was cut at each side of the 'u' of the gasket. I've attached pics. I phoned my mechanic and of course he said they didn't cut anything but he also told me they ran it for about 10 min. to check for leaks and there were none. I don't know how there could not have been. You can see a drip already starting and I had just wiped that and the oil is cold and truck hasn't run since yesterday. I am taking it in tomm. morning for them to look at. So, this doesn't look right, right?
Offline SUX2BU99
Re: Does this look right to you? Need quick feedback.
« Reply #1 on: July 09, 2009, 02:40:58 pm »
Some more pics:
Offline HAULIN IT
« Reply #2 on: July 09, 2009, 03:53:02 pm »
Something is amiss there for sure, they may not have cut it, but it looks torn, broken or something & not in the correct place. Lorne
Offline eventhorizon66
« Reply #3 on: July 09, 2009, 05:49:48 pm »
That is not right.  There is a groove across the rear main cap that the rear section should be nestled in.  That gasket split in the rear left corner.  Take it down to the auto parts store and tell them you want another.  Did you overtorque the rear most bolts?
« Last Edit: July 09, 2009, 05:53:14 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline SUX2BU99
« Reply #4 on: July 09, 2009, 07:15:01 pm »
I didn't put it in, a shop did. This is twice now I've had an issue with them, for 3 items I've had done by them. One was having the heads and cam done, which they did a great job of, but it was the owner that did it. He did it himself because he felt bad for a screw up this his employee did when they put in a starter in a 03 Tahoe we had (item #2). He pinched the crank sensor wires, causing it not to start. They couldn't figure it out, so around $600 in labor and a tow to the local GM dealer, it ran again and they told me what happened. Now this. After they fix this, I won't be going back.
« Reply #5 on: July 09, 2009, 09:30:58 pm »
yeah not properly installed. Like said it needs to be correctly installed then the pan and properly torqued. Find a new mechanic!
« Reply #6 on: July 09, 2009, 09:57:11 pm »
Yeah thats not right. That place has a some simpletons for employees.
Offline SUX2BU99
« Reply #7 on: July 09, 2009, 10:03:03 pm »
Thanks guys. No kidding, eh? How could a person NOT see that was messed up?  I remember driving down the freeway and I heard a big clunk against what felt like my left foot. I don't know if that was the gasket ripping or what, but it was still dripping oil from the night before.
I haven't tried turning it over to see if the piece is just rubbing aginst the flange or if it spins with it. Either way, it ain't right and they are going to fix it and get it right!
« Last Edit: July 09, 2009, 10:04:51 pm by SUX2BU99 »
Offline SUX2BU99
« Reply #8 on: July 10, 2009, 02:04:54 pm »
Dropped it off this morning for them to fix it. He phones me and asks if I had a non-chrome oil pan they could use. He says the chrome is so smooth it makes it hard for the new gasket to grab on and not squish out. I said to sand off the chrome or sand it anyway. He says they'll scuff it and maybe use a thin weatherstrip. I'm phoning back to say what kind of weatherstrip holds up to oil and pressure?
Offline 80stepsideguy
« Reply #9 on: July 10, 2009, 02:12:39 pm »
They cant take a dotco wheel, rough up the metal and lay a thin bead of silicone in there with the seal???If they cant do this then this place has more issues then the national geographic has volumes....
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline SUX2BU99
« Reply #10 on: July 10, 2009, 02:15:08 pm »
^ LOL   I phoned him just now and said "Um, how is foam weatherstrip supposed to hold up to oil and pressure?" He said it wasn't that kind, it was more like a silicone/sealant-type glue and works in these applications. Fair enough. Better work is all I know.
« Reply #11 on: July 10, 2009, 04:30:01 pm »
The oil in the pan isn't under any excess pressure (hopefully). 3M (yellow snot) weatherstripping adhesive works great for gluing gaskets into place. It doesn't add sealability.
Offline baddogg79
« Reply #12 on: July 11, 2009, 09:25:20 am »
and people wonder why I do my own work. Especially when its 20 degrees and snowing out. I rather do that that go to a shop. Hope it gets sorted dude!
« Last Edit: July 11, 2009, 03:01:05 pm by baddogg79 »
Offline blue beast
« Reply #13 on: July 11, 2009, 02:25:28 pm »
yea man that sux.im running that same gasket.oil pan should have a lip 4 it 2 sit in.it should also have crush sleves in the gasket.hope it works nice truck. 8)
chevy tuned up like a nascar pit stop
« Reply #14 on: July 13, 2009, 02:01:47 pm »
My opinion is if it is squishing out, he is tightening the bolts to tight.
