Author Topic: I need help please!  (Read 7917 times)
Offline Twades87chevy
I need help please!
« on: July 14, 2009, 10:06:09 am »
I just went muddin last night in my 87 crew cab 1 ton. I hit a mud pit about  2-3 feet deep I hit it kind of fast and it just died. I try to crank it but it did not turn over. We pulled in out and tryed to crank it was shooting water out my no cats cherry bomb glass packs. We pull up a hill and tryed to it the water to come out. after 15-20 trying to crank it. It started. The point I'm writeing this my trucks not running right. My glass packs don't sound right at all. There is a loud sound when get on gas( motor I think) and it's idleing pretty high . If you can help me it would be great if you need more detail let know thank u so much
Re: I need help please!
« Reply #1 on: July 14, 2009, 10:09:42 am »
Pull all the plugs and crank it over. then do a compression test.
« Reply #2 on: July 14, 2009, 11:27:02 am »
what would that do
« Reply #3 on: July 14, 2009, 12:33:09 pm »
Compression test will tell if somthing is bent or broken.
« Reply #4 on: July 15, 2009, 05:39:57 am »
It will get all the water out of the cylinders!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: July 15, 2009, 11:59:02 am »
if you have water in your cylinders, might you want to change the oil too?
« Reply #6 on: July 15, 2009, 08:54:45 pm »
Can water in the motor cause spark knocks that I hear going down the road
« Reply #7 on: July 16, 2009, 04:44:16 pm »
If you are driving the truck there won't be any water in the motor other than the coolant.
Did you check your oil? do a compression test?
You could very well hydro-loc a motor with water in the cylinder and bend a rod.
