Author Topic: help deciding carb!  (Read 13175 times)
Offline eventhorizon66
Re: help deciding carb!
« Reply #15 on: August 13, 2009, 12:54:10 am »
'85 C10 SWB 350 700R4 TKO600
Offline 83HighSierra
« Reply #16 on: August 13, 2009, 08:20:00 am »
ok i thought that the hole where its marked for the kickdown stud is where the spring attaches... ???
« Reply #17 on: August 13, 2009, 10:48:42 am »
Hooking up throttle return springs with aftermarket carbs often requires a little creativity on the part of the installer.
I would advise making yourself a little metal tab like this:
And installing it under the nut of the kickdown stud like this:
« Last Edit: August 13, 2009, 07:31:04 pm by eventhorizon66 »
« Reply #18 on: August 16, 2009, 12:16:25 pm »
ok i hooked the carb up yesturday like you showed me and it fired up.i did a little adjusting of the idling and it ran perfect. the truck had been sitting for about 7 months with a new motor in it i just couldnt get it started. thanks alot for your help eventhorizon66. you saved me alot of money and hassle.
« Reply #19 on: August 16, 2009, 04:34:10 pm »
Happy to help.  Glad you got it all sorted out.
