Suburbans
6 inch lift.. will 37's fit?
Topic: 6 inch lift.. will 37's fit? (Read 15309 times)
76warpig
July 18, 2009, 03:37:12 pm »
Do you guys think a set of 37" TSLs will fit under my burb after a 6 inch lift without rubbing the fenders? Or do i need a body lift? I love the suburban forum by the way!! I will post some pics of my war pig after i get the body line x on and lift installed. Oh and i need to learn to post pics as well
Re: 6 inch lift.. will 37's fit?
July 18, 2009, 11:16:11 pm »
you need the body lift. with a 6" lift 35 will fit no problem
its kind of hard to read but
http://i333.photobucket.com/albums/m387/rebel_cowboy_83/GeneralMotors.jpg?t=1245234481
thats the link
Last Edit: July 18, 2009, 11:20:36 pm by Irish_Alley
Jake_s
September 26, 2009, 09:31:35 pm »
You won't need a body lift if you're not afraid to trim the fenders. i would avoid a body lift on a 'Burb, too much mass to be raised up on 3" pucks.
If you dont want to trim teh fenders, then get a 8" lift and you'll be fine.
Jake
Chevalade
September 27, 2009, 06:11:25 pm »
Trim the fenders, get a set of cut out flares if you really want it pretty. I plan on doing up to 41's with a 6" lift and trimming.
September 28, 2009, 12:52:19 am »
its probably a little more but my fenders are trimmed and rolled looks almost stock well the lip anyway.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
September 28, 2009, 07:09:51 am »
I hope your rear ratio is like 4.56 or higher number if you wanna put 37's on it. Those bigger tires KILLS your mpg, as if a sub wasn't bad enough as it is. You'd always have to have the gas pedal mashed to go anywhere--even on the interstate whith those big tires.
I've got 33's on my 3.73 rear 4x4 sub and I am going down to 265's next time i change tires/wheels.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
fitz
September 28, 2009, 10:52:39 pm »
Quote from: SgtDel on September 28, 2009, 07:09:51 am
My truck had 5.13's to spin the 44" swampers.
Suburbans
