Author Topic: Going from FI to Carb, What to do?  (Read 9185 times)
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« on: July 25, 2009, 08:11:39 am »
Well after lots of reasearch, head scratching, I have settled in on my repower plans for the winter. I was going to install a 12 valve Cummins, but after all the research, bracketry needs, mounts ect. I have determined that I am going to stay gasoline. I'm going to be building a big block (490 maybe 502) and running a carb(Demon/Holley). I thought about going with a Ramjet FI but engine builder tells me big torque at low RPM's come from carbs. I'm looking for somewhere in the 600-650 ftlbs of torque range at under 3000 rpms for the new motor. The question I have is what's the best way to keep my 4L80E, buy a stand alone computer, or is there a way to keep the ECM from the TBI setup? Anyone done this?
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Re: Going from FI to Carb, What to do?
« Reply #1 on: July 25, 2009, 08:17:03 am »
What is your factory set up? Is it already a bigblock? You can keep the stock computer but you will need the primary input sensors still.
Offline 1HI4x4
« Reply #2 on: July 25, 2009, 11:39:26 am »
It's a 5.7 Throttle Body, I'm going to a big block carb motor, won't I need the imputs from the motor in the stock ECM for the tranny to work?
Offline eventhorizon66
« Reply #3 on: July 25, 2009, 12:34:46 pm »
Aside from the fuel systems used.  600-650 ft lbs at or below 3000 rpm is a tall order for a NA 490-502.  You might consider just building a positive displacement blown 383 or 400.  Magnason and Whipple make an efficient lysholm-style blower that is up to the task of 600 ft lbs in a well built 383.  Or you could just shoot for 750-850 ft lbs and build a blown 454/489.
Another idea, if you require a NA big block, is a Caddy motor.  This one looks like a nice little turn key: http://www.cadillacperformanceparts.com/index.php?option=com_content&task=view&id=19&Itemid=62
« Last Edit: July 25, 2009, 12:40:46 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline 1HI4x4
« Reply #4 on: July 25, 2009, 01:17:02 pm »
My engine builder had one on the dyno the other day that made 635ft.Lbs. at 2850 rpms, it was a 502ci, it had a quadrajunk on it. So I know it can be done, truck has to be very streetable. I don't care about the HP number, I need big torque, I do alot of towing. I don't tow at 4000 rpm's.
« Reply #5 on: July 25, 2009, 04:36:44 pm »
Cool.  Hope you don't mind sharing the specs on the engine you end up with.  That motor must have had some efficient heads.  And I think you just shed some light on the carb you should run.  Why not a Quadrajunk?  They're great for towing.
You can defintely adapt a TPS sensor to the carb.  HAULIN IT just did this in his hot rod.  He also used a Baumann TCM to run a 4L60E.  Maybe he'll chime in here.
« Reply #6 on: July 25, 2009, 04:55:29 pm »
If this is a towing rig, why not run a TBI big Block? You can use a factory harness, ECM and sensors. All you need to do is get a new chip.
Offline 1HI4x4
« Reply #7 on: July 25, 2009, 08:02:50 pm »
I don't think I can get a TBI to produce the numbers I'm looking for.
« Reply #8 on: July 26, 2009, 10:58:50 am »
The engine builder is incorrect as far as EFI goes.  A TBI and/or ramjet is what makes torque at low RPMs, people swap to carbs to get high HP/rpm numbers.  The tunned runners help make low RPM torque  The Ramjet 502 makes 502 horsepower and 565 lb.-ft. of torque, and it has over 500 lb.-ft. of torque available from 2200 rpm on up.
They guys on 454SS.com have some good tips on making power out of the TBI setup.
I would put the 502 in with the current ECM and chip it, upgrade the pump and the injectors/TBI with more flow and you should be close.
« Reply #9 on: July 26, 2009, 11:59:19 am »
I agree with Capt.  If there is one place that carbs will always lag behind EFI, it's low rpm / low throttle conditions.  I've never heard/read anything to the contrary.
But everyone's got opinions and they're all different.  At some point, you've just got to find somebody you trust and stick with what they say.  That is if you lack the experience to make your own decisions. :P
Offline 1HI4x4
« Reply #10 on: July 26, 2009, 01:06:56 pm »
I suggested A Ram Jet Set-up to him and he said that would be a good choice, but he was no fan of TBI. That's when the converstion went to carbs on an old style dual plane intake, ported to match the heads.
