Author Topic: Possilbe sticking lifter/valve, How do I remove sludge?  (Read 5753 times)
Offline BigTowExcursion
« on: July 26, 2009, 05:31:53 pm »
Hey guys, just wondering what you use to flush out your engines.  I have used "Gunk" engine flush at recent oil changes and it seems to release alot of crap. But what else short of dropping the pan can I do? My old man told me to drain the oil and fill up with 50/50 cheap oil and diesel then let it idle for 15-20 min, then drain and change filter and put in good oil.  What do you think?
Michael
BTW my truck is an 84 k-10 350 Eledelbrock carb
« Last Edit: July 26, 2009, 05:34:17 pm by BigTowExcursion »
Offline Skunksmash
Re: Possilbe sticking lifter/valve, How do I remove sludge?
« Reply #1 on: July 26, 2009, 07:22:03 pm »
Keep using that stuff until it no longer releases crap. Other than that all you can probly do is pull it all apart and take it to the machine shop.
« Last Edit: July 26, 2009, 07:26:57 pm by Skunksmash »
« Reply #2 on: July 26, 2009, 09:53:48 pm »
A quart of ATF does wonders. A quart a hundred or so miles before an oil change. Plus a quart of 50/50 ATF and gas slowly poured down the carb while running about 2000 RPMs will unstick a valve too.
The diesel thing works pretty good too. Not sure I would do 50/50 but a quart or two and the rest oil.
Offline team39763
« Reply #3 on: July 29, 2009, 03:35:28 pm »
Have you tried Seafoam?  I heard that stuff clears up gunk pretty good.
« Reply #4 on: July 29, 2009, 05:35:41 pm »
Just buy a can of engine flush and follow the directions. If it's that sludged up you may end up plugging up your oil pump pick up though
Offline joesgarage71
  • Wrench
« Reply #5 on: July 29, 2009, 06:37:44 pm »
 auto-rx.com
Offline MITOYZ
« Reply #6 on: August 07, 2009, 11:07:19 am »
Seafoam works great plus you'll kill all of the mosqitos around if you also run it through your vacum lines.Get 2 cans for everything.
  • Wrench
« Last Edit: August 14, 2009, 12:08:27 pm by joesgarage71 »
