Brakes and Braking Systems
brake problem
Topic: brake problem (Read 5191 times)
Low87c10
brake problem
July 29, 2009, 06:02:27 pm »
Finally got the beast running, now a new problem has sprung up. Left front brake is dragging...if I open the bleeder, it releases, but goes right back to dragging as soon as I hit the brakes. Any ideas?
Re: brake problem
July 29, 2009, 06:05:54 pm »
Replace the caliper hose. (I would do both at the same time.)
modular93fox
Re: brake problem
July 30, 2009, 09:06:30 pm »
i would be on the hoses too. since you will be changing the hoses soon...when is the last time you changed your brake fluid? every 2 years is recommended
5.3 4l60e
Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Low87c10
Re: brake problem
July 31, 2009, 03:45:26 pm »
Yep, it was a bad brake line. thanx for the help and support
brake problem
