Author Topic: A/C queston  (Read 6398 times)
Offline topnotchchevy
A/C queston
« on: August 04, 2009, 01:16:56 am »
I want to fix my a/c in my 1979 Chevy Silverado C-10 1500 it has a 305 i need to know what kind of compressor it needs and what kind of bracket it needs to place the compressor on there. If you have any ideas or pics of what it looks like please let me know i would really apreciate it. Thanks.
Re: A/C queston
« Reply #1 on: August 04, 2009, 04:52:59 am »
What compressor was on there?
Offline Prong
Re: A/C queston
« Reply #2 on: August 04, 2009, 06:07:44 am »
A factory air setup should have an A-6 compressor. Brackets should be a dime a dozen at the boneyard.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: A/C queston
« Reply #3 on: August 04, 2009, 07:17:45 am »
This is my 79 after I replaced the 350 w/ the 383....
and the rear bracket is seen here when I was stripping out the 350.....
« Last Edit: August 04, 2009, 07:19:31 am by SgtDel »
Re: A/C queston
« Reply #4 on: August 04, 2009, 03:03:05 pm »
So the compressor would have to be an A-6 right?
And isnt there like a specific bracket for the compressor?
Re: A/C queston
« Reply #5 on: August 04, 2009, 10:27:15 pm »
It could be an R4 also but it really doesn't matter since you obviously don't have the bracketry. Find a donor
Re: A/C queston
« Reply #6 on: August 04, 2009, 11:53:48 pm »
Ok so by donor you mean i can just take off any bracket and compressor from any other 305 and place it on mines right?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: A/C queston
« Reply #7 on: August 05, 2009, 06:38:08 am »
the right kind of bracket for the right kind of compressor.
some more pics of my 79 when removing the 350...
note bracket attached to power steering
note the exhaust type bracket as well
« Last Edit: August 05, 2009, 04:24:46 pm by SgtDel »
Re: A/C queston
« Reply #8 on: August 06, 2009, 05:17:03 pm »
Ok those pics really helped out thanks ima go to the junkyard to look for the brackets.
