Author Topic: Coolant temp sensor  (Read 3349 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Coolant temp sensor
« on: August 07, 2009, 10:50:05 am »
87 silverado 305 tbi. Is it possible for the cts to be faulty and read hot at all times? When you start the truck cold it hesitates when you take off. Once it gets warmed up it is fine. The sensor is cheap so I will buy one, I am just curious if this is possible.
Re: Coolant temp sensor
« Reply #1 on: August 07, 2009, 01:45:00 pm »
Usually it works the other way around. The resistance goes up and the temp goes down.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: August 08, 2009, 03:05:13 pm »
Replaced sensor and no change. Removed cat convertor and hesitation went away so I guess it was plugged. I will just have a new dual exhaust put on and eliminate the cat. No smog check here
