Author Topic: OIL PUMP ? ? ?  (Read 4510 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
OIL PUMP ? ? ?
« on: August 12, 2009, 07:38:34 pm »
Hello all!
what's the best oil pump to use in my stock '78 350???  Isn't there is a HIGH PRESSURE pump and a HIGH VOLUME pump?  I may as well install a new pump while I am replacing the rear main seal and the pan gasket!
Please advise and thanks!
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Re: OIL PUMP ? ? ?
« Reply #1 on: August 12, 2009, 08:52:35 pm »
I read somewhere that the stock type oil pump is more than adaquate for what I assume is a stock application.  I am sure I will be corrected if I am mistaken.
Offline eventhorizon66
Re: OIL PUMP ? ? ?
« Reply #2 on: August 12, 2009, 09:08:33 pm »
+1.  Stick with a stock volume pump.  If you wish to do your oiling system a small favor, disassemble the pump and apply a nice radius to the internal exit passage.  Also relieve and radius the inlet at the rear main cap.
'85 C10 SWB 350 700R4 TKO600
Re: OIL PUMP ? ? ?
« Reply #3 on: August 12, 2009, 09:17:39 pm »
yes, use a stock pump and pick up but use a steel sleeve driveshaft. Put a tack weld or jb weld around the pick up after you set it.
