Author Topic: 14 bolt 10.5 help  (Read 12090 times)
14 bolt 10.5 help
« on: August 15, 2009, 12:33:28 am »
OK i think my pinion bearings are going bad the shaft has allot of play. not talking bout slop just play you can wiggle the shaft pretty good all around. my question is b4 i tear her down i can get to the bearings by the yoke cap what ever its called, but where would be the best "cheapest" place to buy them from, I've look on line and found a couple but just looking for some feedback
Offline joesgarage71
  • Wrench
Re: 14 bolt 10.5 help
« Reply #1 on: August 15, 2009, 09:09:38 pm »
Everything you ever wanted to know about a 14 bolt.
http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
« Reply #2 on: August 16, 2009, 11:22:41 am »
You can get the bearings from any auto parts store.
« Reply #3 on: August 17, 2009, 02:28:59 am »
finally fixed my front drive shaft today and decided that i would go mudding with a buddy so went into the pit and the front does nothing its locked front shaft is turning but still nothing. i don't know whats wrong with it, now if you hit the higher rpms a lot of noise comes from the front. the shaft i used i know came from another 44 but the snap ring that holds it in place in the hub well the grove was a little farther back that the one we took out so we had to cut another grove in the shaft for it to work. now not knowing what year the shaft came out of why did we have to do this what years did they change this up?
  • Wrench
« Reply #4 on: August 17, 2009, 07:43:21 am »
what year are you working on? D44?
 Something ain't right, maybe I can scan the manual and send you some pages.
 Steve
« Reply #5 on: August 17, 2009, 11:52:06 pm »
if i had to guess i would say mid to late 70's in my truck and the other i don't have any ideal on what year it is but i would say some were in the 80's
  • Wrench
« Reply #6 on: August 21, 2009, 06:33:55 pm »
Heresa some info to repair, you can find the numbers and date the diff.
http://www.offroaders.com/directory/axles/dana44.htm
« Reply #7 on: September 06, 2009, 01:04:45 am »
on the 14 bolt how do you tell what case it is. i know its a 10.5 but i haven't seen a tag to tell what came in it stock apparently theres a difference in the 4.10 rear and 4.56 but you can put a 4.56 that is thicker to fit in the 4.10
« Reply #8 on: September 13, 2009, 01:12:34 am »
OK took the 14 bolt apart fount the "A" bearing to be missing found parts all over and "B" the nose of the pinion was warn. so i guess I'm going to have to replace ring pinion and bearings :'( but i guess you play you pay ::)
« Reply #9 on: September 15, 2009, 01:40:46 am »
OK update. got to thinking bout it and with the damage done to the pinion in the rear dif. and the problems with the front dif. i called a friend who's family owns a junkyard he had a couple sets of rears. ones a 14 bolt ff 10.5 and Dana 44 not sure of ratio, the other in 14 bolt ff 10.5 w/ a Dana 60 took it apart and saw it was a 4.10. come to find out thats what i already have in my truck it was OK for the 38s but I'm thinkin about 44s, probably have to use low allot more now than b4. price for eather is 300 gears in the front look OK fluid wasn't too dirty kind of new but had a little darkness to it. so i figured 300 is about what ill be paying for just in parts for one rear to rebuild and the wify agrees thats what matters ;D
  • Wrench
« Reply #10 on: September 19, 2009, 05:56:55 am »
44's are going to need a 456 gear. the 14 and the 60 are the way to go. You'll be stressing the D44 with 44's
« Reply #11 on: September 19, 2009, 06:19:15 am »
but i could use the low trany gear or low 4x2 then go 1,2,3, and shift back to high 4x2 then go to 1,2,3 lol who am i kinding thats too much shifting for my lazy butt ::)
Offline Chevalade
« Reply #12 on: September 20, 2009, 02:06:49 am »
Recipe:
You take 1 part D44, add 4.56 gears.
Then mix in some 44" rubber, rocks, and mud.
Mix, beat, and stir for 1 hour......
Finished Product = Trip to get the D60 and decent parts for it.
« Reply #13 on: September 20, 2009, 02:21:47 am »
lol. well we don't have rocks on the easternshore of MD well not around my area so ill only be getting dirty
Offline Chevalade
« Reply #14 on: September 21, 2009, 07:13:25 am »
Heck I don't have rocks either, but I am going to run the 60 with 37's. You definately need a 60 going anything 40+". A 44 just can't handle the weight of 40's. Bearings go, rod ends are toasted.....etc. In the long run it would be cheaper to get the 60.
