Author Topic: Possible Transmission Issues??  (Read 19065 times)
Re: Possible Transmission Issues??
« Reply #30 on: August 25, 2009, 08:20:36 pm »
pinch off the return hose and drive it. Report
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #31 on: August 26, 2009, 07:32:59 am »
I'm sorry, are you refering to the return on the fuel system or tranny?  Thanks ???
Don't wear a tux without the BOWTIE!!!
Offline eventhorizon66
« Reply #32 on: August 26, 2009, 10:24:46 am »
« Last Edit: August 26, 2009, 10:26:21 am by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline Marc
« Reply #33 on: August 26, 2009, 10:56:16 am »
I'd suspect fuel as it wouldn't be very beneficial to clamp off a transmission line.  Also try disconnecting your ac clutch.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #34 on: August 26, 2009, 02:02:24 pm »
LOL, Yeah I guess that make sense.  I have disconnected the Clutch from the A/C, nothing changed.  Vile I have steel braided hoses at the TBI (OEM) and hard lines down under the truck.  I obviously can not pinch off the hard lines but will I damage the steel braided lines if I pinch them off?  If I can ask what will this do?  I'm curious.  Does it raise the pressure in the system?  Thanks
« Reply #35 on: August 26, 2009, 04:55:05 pm »
It won't damage them unless you are pinching them off with wire cutters.  It raises the pressure at the TBI.
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #36 on: August 27, 2009, 07:20:52 am »
LOL, Thanks Capt.  I'll try that tonight and report back.  Thx
